Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Screen is cut off top/bottom
My Westinghouse 32" hdtv is cutting off the top and bottom of the screen in standard mode. Obviously Fill and Overscreen modes are far worse. How can I reset the screen?
I had the same problem on my 47 inch Westinghoust HDTV. It turned out to be a problem related to my satellite tv (Direct TV) remote controller. Someone inadvertently hit the "format" key and jacked it up. I set back to it's original position and get the full screen. Don't know if you have cable or satellite, but this may help someone having this problem,
Posted on Mar 13, 2009
The top and bottom is cut off as well as the right and left also cut off
Two things Some TV programs do not fully fill the screen. Nothing you can do about that. The other is the high voltage circuits are no longer producing the correct level of voltage to fill the screen If it's an old TV, it might not be worth the cost to repair.
Feb 02, 2016 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I too have the problem where the top and bottom of the picture is cut off on the TV screen. No formatting of any kind fixes it. What is the answer?
Some of the wide screen programs will leave blank strips top and bottom of the screen, you can fill the screen if your TV or the remote has picture size buttons where you can select "movie" mode or "movie zoom" modes. try stepping through picture size buttons. Some times it is marked as "wide" on your remote.
Jan 03, 2010 | Envision L32W761 32 in. LCD TV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
I have the tv in standard mode, but I am unable to
I bet you are using a cable box or satelite receiver. If so check for aspect buttons on the remote that control these devices. I know comcast says "HD Zooom".
Apr 21, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Nov 30, 2008 | RCA F32650 32" TV
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
258 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
