Question about Hotpoint Washing Machines
Hotpoint Aquarius WD22 Dryer functions, as in turns and blows, but NO hot air
    Problem Solver:
  • 9 Answers
The only thoughts that spring to mind, are either...
A: The dryer heater has packed up.
B: The tube/funnel that the air flows through to the drum is blocked with fluff.
In either case you'll need to take the lid and sides off, locate the dryer duct then find a way of opening it to clean the fluff out.
If you need any more help, message me.
Posted on Aug 03, 2010
Tumble dryer not heating
If the fan in the aluminium bit on top sticks then the thermal fuse at the front blows
Jun 29, 2015 | Hotpoint Aquarius WD640 Front Load...
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Hotpoint aquarius dryer blowing cold air.can it be reset?model tdl32
Check the heating element and thermal fuses for continuety
Mar 19, 2010 | Hotpoint TDL14 Electric Dryer
Help! hotpoint aquarius condenser dryer
More than likely thermostat or heater.
Located at rear of dryer behind removeable panel, you will need a meter to test them.
Jan 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I HAVE A HOTPOINT AQUARIUS WD62 WASHER DRYER. THE DRYER FAN TURNS ON BUT DOES NOT HAVE ANY HEAT COMING THROUGH, ONLY BLOWING COLD. CAN YOU SUGGEST WHAT NEEDS CHANGING? THANKS - RICHARD S
It will be a faulty thermostat or element more than likely, or a broken wire.
Remove top cover, and you will see the heater manifold over to the right side, there you will see the element and thermostats.
You will need a meter to test them.
Hope this helps.
Jan 10, 2010 | Hotpoint Aquarius WD63 Front Load...
Dryer blowing hot air but not turning
You have a broken drum belt. Ask your friendly appliance parts guy to sell you one..
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
The t-stats have blown.. these are located on the top of the heater on top of the drum.. To check to see if their blown check the continuity if they are blown then there will be no continuity ... They come in a pair and are easily replaced.. All you have to do is take off the lid...
Nov 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
166 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
