Question about Cuisinart DLC-XP Plus 20 Cups Food Processor
Jammed Blade The blade on my machine has gotten stuck on the shaft for the second time under normal operation. The first time I took it to someone who removed it and wouldn't tell me how. Any ideas on what to do?
Had the same problem. The Cuisinart folks said to fill it with hot tap water - not boiling - then turn it on and off. The heat from the water will unstick the bowl. If it doesn't work first time - refill with hot water and try again. Worked like a charm for me.
Posted on Dec 01, 2007
The bowl of my 14 c food processor will not release from the base - the cutting blade is in place
You will probably need to force the blade off the shaft somehow. If you over work them the blade can partly turn and lock onto the plastic shaft sleeve. A Kitchen Aid Authorised repairer will have figured out a way to remove it by now because it's been happening for years. Expect to replace the blade or the sleeve or both, once it's happened it's easier to happen a second time unless you replace parts.
Nov 23, 2017 | Food Processors
Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Jun 16, 2007 | Cuisinart DLC-5 Food Processor
How to remov blades
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5.
Aug 11, 2014 | KitchenAid Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
My blade is stuck on, how do I get it off?
May 28, 2014 | KitchenAid Food Processors
I have the 14-Cup Cuisinart Elite Collection Food Processor. Up until recently it was working fine. Recently when using the shredder blade, when I insert food into the feeding tube the blade stops...
If the unit works OK with other attachments and the problem is only with the one cup; then the blade may be loose and spins on the shaft, the connection gear under the bottom is worn or binding up. Debris is stuck around the blade shaft or from heating up the metal parts expanded and bind when turning.
Mar 10, 2014 | Cuisinart Food Processors
The cutter assembly is stuck and cannot be removed form machine
The plastic shaft broke and was stuck on the motor shaft. It had to be broken completely to remove it.
Jan 19, 2010 | Bravetti Platinum Pro Quad-Blade Food...
My Cuisinart Pro Classic is leaking! When I tried to make corn pudding at Christmas, something I've done many times before, the liquids poured out all over the counter. Everything seemed in place and the...
it is either the seal around the blade shaft that is worn (but if it is worn so much that liquids can leak, then you probably heard the machine vibrate more than normal or sound screechy). Or it is the gasket at the bottom of the container that is not seated well or is out of shape. Goodluck, Macgivor
Jan 16, 2010 | Cuisinart DLC-10S Pro Classic Food...
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
Cuisinart DLC-XP Plus 20 Cups Food Processor Logo
871 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
