Question about Philips GoGear HDD1830 MP3 Player
Phillips gogear 8gb will not play
Can choose a song, press play, but the device will not play the song, screen shows duration on right side, i.e.: 4:03 / but the timer on the left side always shows : 0:00
  • 8,596 Answers
Press play again - you have to press it twice.
Posted on Dec 09, 2008
PHILIPS GOGEAR 8GB STUCK on the screen showing that Go gear & if I press the reset buttan it wont works what should i do?
read owners manual,you can look inside manual also for technical support number they will help you.any time you buy devices they have instruction manual that tell you how to operate device.
Nov 13, 2011 | Philips GoGear Micro Jukebox 8GB...
Don't know how to delete files off the device
you should be able to delete them from the play screen! I have the 8GB version phillips gogear vibe!
thats how i delete songs!
Play the song you want deleted, the hit settings, and scroll down to delete!
Good luck
Jan 21, 2011 | Philips GoGear Flash MP3 Player
I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Dec 27, 2010 | Philips GoGear ViBE Digital Media Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
Phillips gogear play downloads songs but doesnt downloaded song
in philips go gear device it wont show the song or video unless or untill its a compatible one(e.g it wont play real player .flv files) to the player..check whether you can play the song from the device in your computer. if yes try a different youtube converter software.
May 24, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear 8GB wont show song titles or artists.
the phillips go gear mp3 player is a total pice of **** the best thing you could do is go out return it and buy a sandisk sansa other wise called a sansa fuse they are great and they have an expandable micro sd card port.
oh and to fix your phlips go gear mp3 player you need to take a pin and stick it in a small hole on the side i belive it is on the left side next to the mic.
Feb 12, 2009 | Philips HDD065 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Reset
Please through your phillips go gear to dust bin
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips 8gb mp3
There is a step left out of the repair instructions on the website/device manager itself:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Oct 21, 2007 | Philips HDD1630 MP3 Player
Wont connect
Try using Windows Media Player (version 11 should be fine) to sync music files to it. Using drag-and-drop to the device folder only sometimes works (and usually doesn't).
May 31, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
