Question about GE Dishwashers
Ge dishwasher hums but will not work. is a 1999 model,,seldom use
Maybe uses 6 times a year. Water valve is on.
  • 1 more comment
  • escamry Nov 16, 2008
    Please help. Basically use at holidays. so practically new
    thank u for your help. It still won't run, but will try it again.
    No i didn't do that, not sure I can, I see the pump motor (black round), but couldn't get to the blade part. Will I have to remove something??? Again Thanks for your help
  • 1,543 Answers
When you use your dishwasher so infrequently the water inside evaporates and allows the pump seal to dry out, so there is no longer the lubricating water there. You may be able to solve this by pouring a couple cups of hot (not bioling) water directly into the center of the lower wash arm (center spray tower) and letting it sit for several minutes.
If that does not work, you can take the bottom panel off and turn the fan blade on the motor by hand until if turns freely. (don't do this with power to the motor or you may have some nasty banged up fingers !)
To prevent this from happening in the future, keep some water in the dishwasher by poring a bit in every now and then, or by running a fill and pump cycle at least once a week or so. If you are away for extended periods, you can try adding RV antifreeze to the dishwasher while away.
Posted on Nov 16, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 16, 2008
    Did you try turning the fan blade of the pump motor? It may turn hard at first. Make sure to do at least a full revolution.
    Carl Schulzetenberg Nov 17, 2008
    blade part is toward the pump side, away from the wires. will not have to remove anything further than you already have.
I just moved into my apartment
perhaps the water inlet valve is shut off. Follow the plumbing, turn it back on. It maybe located in the bottom 6" of the dishwasher, or close to it in an adjacent cabinet or wall. Mine is in the basement laundry room
Jul 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
GE Dishwasher will not fill with water
You probably have a bad water valve. It is not expensive to replace. About 25-30 dollars. Go to an appliance dealer and tell him the model and he will sell you the part. It is fairly easy to replace too.
Jan 25, 2009 | Dishwashers
Washer is overfilling
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishes not clean, soap still dripping down from dispenser.
yes its the water that washes that soap out,no water no wash.so a couple of things.eazy first.im asumming it drains fine.1 so check the flood switch dome,its in the tub ,frount area if enpty should be down.if you pick up ,will hear small click.2 [harder] with a volt meter put the probes into the water valve.its in bottem behind panel most of the time its blue,so whiteor yellow.with probes in water valve connections.turn on dishwasher at begining of cycle.after short time should get 110 volts if yes need to clean out valve[minerals]or replace because failed.God bless,tom
Jan 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore dishwasher mod # 363.14375791 hums, wont fill or run
Are you sure the valve is what is humming? If so, it may have went bad again. Its not unusual for that to happen. You could possibly have a timer going bad, or a ground issue. If it is the valve humming, check your water supply, and be sure you dont have a clogged line. Also, some valves have inlet screens over the end of the inlet valve (would be just inside the fitting where it goes into the valve). These can become clogged as well. Let me know what you find out.
Nov 15, 2008 | GE Dishwashers
Leak from a black module, where an arm connects
if your dishwasher leaks check out this: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 11, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
GE dishwasher will not start cycle
Yes,it could be a deffective inlet valve. But before replacing it check first water inlet line's filters (on its both sides) In case it will not help- test that the valve get power. In case it get power and doesn't work - You can easily open the valve and clean it from scale or other dirt. Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new one Good luck!
Aug 08, 2007 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwashers Logo
156 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
