Question about Cyberhome CH-DVD 300 DVD Player
I change settings
I was changing some settings in my dvd and suddenly the screen went black and my dvd didn´t respond anymore to the remote control. I desconnected the dvd for about 3 months and now that i turn it on, it still doesnt work, the audio works but it doesnt have any image. I cant remember which button or what setting i changed , i suppose that i desconfigured the dvd. What can i do?
  • i like to change the mode ntsc but suddenly the video dissapear. what would i do to fix or to reset it?
  • vital357 Apr 13, 2008
    I have CyberHome CH-DVD 300. I changed setting (SETUP) from NTSC to PAL and now cannot change it back . How do I reset the DVD (I tried to hold the stop bottom for 10 sec and it did not work).
    Thanks
Great, it worked for me too. Just hold the stop button for 10 secs with no disc inside. It resets and images shows up. Thanks a lot for all of you.
Posted on Apr 06, 2007
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
Posted on Dec 24, 2006
I found this solution effective... my dvd works!! The only thing I will add is that you need to make sure there is no dvd/cd inside. Then you proceed to reset it, it's usually done by pushing one of the buttons on the unit for 10 seconds (in my case the stop botton)-- (the light will flash from green to red and the go back to green)... that´s it!. Good Luck!! :)
Posted on Feb 21, 2007
You need to reset it, it's usually done by pushing one of the buttons on the unit for 10 seconds or so with the power on (yellow/green light is on). Which one varies on different units, just keep trying till you find it, the unit will shut down (light will go red)when you get it right. P.S. you probably changed the setting with S-video, which is in video in the set up menu. WHen you reset you should be seeing the picture again.
Posted on Dec 22, 2006
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Aug 06, 2012 | Televison & Video
We have a 42' plasma flat screen model PD46C10. All of a sudden it went to a white screen with daewoo in blue. No remote function, no controls function on TV base. Won't shut off unless unpluged. Any...
is it perhaps a built in screen saver? try changing channel on remote. or check to see if input is on aux / or component/ dvd etc.. or possibly there is an access code (parental setting) try that first. hope it helps.
Oct 17, 2010 | Daewoo Televison & Video
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
Have sound, no video
Pressing the I/E button on the remote control repeatedly until the DVD blue screen appeared fixed the problem.
Jan 03, 2009 | Televison & Video
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Sony DVP-NS67P DVD player problem
put dvd player in stand-by mode, press 3 6 9 on remote and press power. picture will come back.
Oct 06, 2008 | Sony DVP-NS315 DVD Player
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Coby 626 DVD Player Remote Not Working
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Mar 18, 2007 | Coby DVD-224 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
131 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
