Question about KitchenAid KGYS850LT Gas Dryer
Gas dryer makes loud hum
When I first turn on the dryer it has a loud hum, but then quiets down after running a few minutes. Why? It's a whirlpool about 10 years old.
  • mrna0400tx Nov 16, 2008
    The gas dryer is a GE model DBXR463GD2WW Serial MH747262A
  • mrna0400tx Nov 17, 2008
    REVISED INFO. ON DRYER
    When I first put in a wet load and turn on the dryer it has a loud hum, but then quiets down after the clothes begin to dry and get lighter. Why?
    It's a GE 3-4 years old. The gas dryer is a GE model DBXR463GD2WW Serial MH747262A
  • 240 Answers
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Posted on Nov 16, 2008
  • James Greene
    James Greene Nov 17, 2008
    The noise is worse when the clothes are wet is because the belt that turns the drum is connected right to the motor itself, so as the clothes get drier, they also get lighter, so there is less strain on the motor.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer Model GGW9200LW0. drum will not start rotation, makes temporary hum noise. after turning the drum by hand a couple time i was able to get the dryer to work for about twenty minutes. but...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
Maks loud squeeling noise when first turned on then quiets down after a few minutes of running
drum rollers/glides, belt is wearing or idler arm is wearing:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 04, 2011 | Frigidaire FGR231A Gas Dryer
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
My Maytag dryer (model no. 3758AYW) makes a loud humming noise...otherwise it works. Vent was disconnected and it still hums continuously when turned on. This is supposedly a "Quiet Series 200".
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This often indicates that the motor is going bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 17, 2010 | Whirlpool LER5636P Electric Dryer
New Maytag dryer model mgdc400vw makes loud humming noise
Weird, try making sure it is level, and make sure your vent pipe aint too long. Tip the cabinet back while running if the noise goes away the damn metal vent pipe is too dang long.
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
it sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Dec 31, 2008 | Dryers
KitchenAid KGYS850LT Gas Dryer Logo
513 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
