Question about Rockford Fosgate Power 351M Car Audio Amplifier
Installing a rf 351m
Not sure how to do all the wiring on this. Only hooking to one 8" sub. Would like to get the best out of it
  • 68 Answers
Hook up the power to the battery and the amp then hook the ground up to the body of your vehicle then hook the RCA's to the back of the radio and the amp. Then you have to run the remote wire to the back of the radio and to the amp. On the speaker outlets you can either hook it up bridged or regular but bridged will get you more bass or power.
Posted on Nov 18, 2008
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
RF p2d2 12 smoking
you cooked the coil in the sub when you see smoke you have clipped the sub. improper wiring probably the issue ohms must match gain must be set properly . if you had gain all the way up thats what did it.
Jun 20, 2013 | Rockford Fosgate Car Audio & Video
Need firng diagram for plug wires to distribor on 351M Ford * made in 1081
Hi there:
I suggest to check this diagram on...
Ford Engines: 5.0L HO, 351W, 351M, 351C, 400
Ford Engines: 5.0L HO, 351W, 351M, 351C, 400:
Rotation: Counter-clockwise
Firing Order: 1-3-7-2-6-5-4-8
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 23, 2012 | Ford F-150 Cars & Trucks
Placing correctplug wires on correct post on ditrbutor cap on 1981 Ford 351ml
Sep 23, 2012 | Cars & Trucks
Diagram of plug wires on dstributor cap1981 F150 351m
Hi there:
Sep 23, 2012 | 1981 Ford F 150
I have a jl 2 ohm stable amp but my speakers are 4 ohm dual how can I run my speakers to where they both are at full power
Unless you have a 2 channel amp, the best you can hope for is a 4 ohm load. If you hooked both subs up in parallel, you would get a 2 ohm load for each sub. You would then have to wire them in series to equal a 4 ohm load. Even if you wired each sub in series, or a 8 ohm load, then both subs in parallel, you get a 4 ohm load. The other outlandish option is to get 2 more dual 4 ohm subs. Then you can get to a 2 ohm load. Sorry, I'm sure that's not what you wanted to hear.
Aug 14, 2011 | Car Audio & Video
Amp power wire is going to battery with a fuse, remote wire is hooked up to the solenoid. The amp and sub work fine when the key is on, but when i start the car, the amp light dont come on but there is...
The remote wire goes to the back of the radio to blue remote or pwr antena blue wire, solenoid? No idea ..Is the amp on all the time, the radio is suppose to turn it on and off..
Mar 05, 2018 | Rockford Fosgate Power 351M Car Audio...
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
Oct 15, 2010 | Rockford Fosgate Power 351M Car Audio...
Contracts or expands, and just stays there
bad connection check spk wiring and rca out behind radio make sure connection is rite
Apr 04, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
Rockford Fosgate Power 351M Car Audio Amplifier Logo
113 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
