Question about Bushnell 2.4 x 29mm Night Vision Compact Monocular Scope with Illuminator 26-2429
Dosent work we have purchased this second hand and does not work when we opened it the wires had been cut can you help
    Problem Solver:
  • 15 Answers
Get a technican to give it the once over - the wires may have been cut because the equipment is unsafe to use. If not, they should be able to fix the damage as the circuits are quite simple.
Posted on Nov 29, 2008
I have an acura 2000 tl and the radio wiring harnes was cut off is there a diagram for this or is there a plug in adaptore so i can use the factory boss system and navigation with a diffrent radio
Hi Alberto,
It will be difficult to purchase just the factory connector for the rear of your stereo and nav system. The best thing to do in this situation is to try and find a second hand radio loom from a car wreckers/junkyard and fit the radio loom in place or have a autoelectrician wire the second hand loom in place.As for the wiring diagram, I do have one but it is in 3 parts and you will need the factory plug to wire the loom into.Let me know how you get on and I will send you the diagram when you require it.
Sep 13, 2011 | 2000 Acura TL
There are cut wires and no cord for the second hand dishwasher i purchased and I need to find out what wires I am connecting and where
There should be a small junction box under the dishwasher behind the front toe panel. There should be three wires:
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You can purchase a three conductor power cord from any hardware store. A 3-prong power tool power cord works the best, as they have a durable outer sheathing and have good current handling properties.
Simply match the corresponding colors (black to black, white to white) and ground the green wire to the chassis. There should be a ground lug somewhere to connect it to.
Use wire lugs when splicing wires together and use the wire strain relief (if equipped) on the junction box. The strain relief is located at the point where the wire enters the junction box and keeps the wires from inadvertently being pulled.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 29, 2010 | Maytag 24 in. MDB5601AWS Stainless Steel...
Replaced batteries in my key fob for my shogun( its the spare key witch has been idle for 2 years ) but now this needs to be reset
hi steve, well i dont know if it will work with your vehicle, but ime a bit confused as to which one you have shogun or outlander? but, either way you can try this, it might work but it might not, this seems to be a mitsi re programing thing...first , locate the data link plug ( obd plug or diagnostic plug as it is known) obtain a length of wire, as you look at the plug it will look like a pirimid with the top cut off ( sorry cant explain it any better) the TOP LEFT HAND SIDE( long bit) as you look at the plug, incert the wire in the first pin (pin 1), then connect the other end to a suitable earth on the body, with yourself inside the vehicle, shut all doors, press the hazard warning light 6 times within 10 seconds, the doors should lock then unlock, press the remote control lock or unlock (dosent matter wich) once, then press the lock or unlock button twice within 10 seconds, doors should lock then unlock, then you should have a programed key again, i hope this works for you, good luck
Feb 09, 2010 | 2003 Mitsubishi Outlander
4 year old Panasonic 1250 Inverter cuts off after five seconds
most likely faulty over temp cut out or safety faulty. Try open it up and clean out fluff. Be sure to remove from power before hand,.
Sep 19, 2009 | Panasonic MCM INVERTER
My stock radio plug is cut off
Hello styxrivercan,
See if the color codes on this modifiedlife page match up with the cut wires. If not, I'd try www.installer.com.
Hope this helps.
Jul 19, 2009 | Pioneer DEH-1600 CD Player
2003 beetle convertable driver side window does not open and close when the door is opend also the door side light dosent work even after a new bulb was installed I think the wiring is somehow conected...
Take a good look at wiring running in to door at hinged end. You may have to open up the loom enough to see wires. Look for an area that appears weak,kinked, or shows signs of where it bends all the time, you'll probably find a wire or 2 showing signs of cracks, or ready to break. Disconnect battery for safety before cutting.Cut wire(s) at weak point, strip both ends,slide some shrink tube down one end past stripped part, then solder together if possible, but if not available, a good **** connector if you have room, but also shrink tube it after you crimp it, for added strength & protection.
Feb 20, 2009 | 2003 Volkswagen New Beetle Convertible
Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Bushnell 2.4 x 29mm Night Vision Compact Monocular Scope with Illuminator 26-2429 Logo
97 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
