Question about RCA Audio Players & Recorders
I bought an RCA digital clock radio # R p5640. I cannot get FM. The band button goes everywhere but FM and that is the only station I listen to. I can't take it back because I bpought it at Circuit City for 10% off and all sales were final!
  • 86 Answers
I dont blam ya, so it dont have the fm channel selection at all? if it dont its most likly just set for am an all, witch would be weird
Posted on Nov 16, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
Preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
Apr 05, 2014 | 1997 Isuzu Hombre
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
How do I preset different radio stations?
Hello
There are 6 preset position available for each radio band.
For programming, Radio must be ON. Tune to a station. Press MEMO/DEMO. Press any button 1 to 6. The tuned station will be memorised on the number you select by button press. Repeat using a new station and preset number. There is no atu preset option available with this device. You have to store stations you want according to your preference. Only 6 station positions for each band [total 12 positions] together with AM and FM bands.
To recall the stored stations, press the desired number 1 to 6.
Dec 07, 2011 | Sharper Image SI785 Clock Radio
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
When using the FM tuner I have to click buttons multiple times before it responds. It also does not keep the clock display up to date . . . acts like the processor is overloaded. This only occurs when...
I have the same problem and not just with the FM tuner. I have spoken to Aluratek about the sluggishness of this radio. Their reply was to not push the buttons ore than once. The radio will eventually work.
Sep 28, 2009 | Aluratek AIRMM01 Internet Radio Alarm...
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
Help
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Apr 06, 2008 | RCA RP5430 Clock Radio
47 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
