Question about Creda C362E Electric Kitchen Range
Not heating up
My creda oven is
not heating up
  • Anonymous Dec 07, 2008
    the hob and top oven are working but the bottom oven is lighting up but no heat
  • Anonymous Dec 15, 2008
    bottom ovan not heating up but fan still works
  • Creda Master
  • 3,463 Answers
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Posted on Dec 21, 2008
  • damien o neill
    damien o neill Sep 07, 2014
    is their a hidden fuse on this cooker
3 Suggested Answers
SOURCE: creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Posted on Sep 06, 2008
  • 142 Answers
SOURCE: CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
If the fan is not turn its not circulating the heat normally you can hear a humming noise if the fan has siezed.It does sound like you need a new fan motor.
Posted on Sep 29, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How to fix creda cooker all of the hobs when put on are unable to control heat
[PDF]Product Directory Summer 2013 - Creda Heating
www.credaheating.co.uk/assets/kb/brochure/.../Creda_Nobo_Brochure.p...
Creda Heating range, installation and operating instructions, brochure ... installations. We are able to offer an expert application design service for all our.
The Different Functions And Uses Of The Oven - Creda ...
www.manualslib.com > ... > Instructions for installation and use manual
Creda J052E Instructions For Installation And Use Manual: The Different Functions And Uses Of The Oven ... For all other types of. cooking, never ... cooking functions are set up by operating the two knobs: ... The oven light turns on and the top and bottomheating ... permit reaching the maximum (250°C) temperature inside.
[PDF]Instructions for Installation and Use - you
Jan 24, 2016 | Creda Kitchen Ranges
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Oven not heating
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 30, 2010 | Creda Europa E010E Electric Single Oven
My c561e creda main oven(fan assited)will not heat up.everything else works
Most likely it is a blown heat element, you could check it if you have a multimeter or continuity tester.
Dec 15, 2010 | Creda Europa E010E Electric Single Oven
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
Creda cooker not working properly
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
Creda C362E Electric Kitchen Range Logo
648 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
