Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Nothing will print, stuck in ''Printing'' mode.
My printer was working fine, however I recieved a fax and ran out of paper. So the data was still there for the printer to print. 3 days later I put some paper in the loader and the fax resumed. It stopped just short of finishing. Now when I try to clear the data, or cancel, it wont let me. On the screen it shows "Printing" but its not working. Any suggestions?
    Genius:
  • 1,124 Answers
Delete all documents on queue.
If you can not do it, Reset the printer.
If you need more help go here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc240c_all.html?reg=us&c=us&lang=en&prod=mfc240c_all
Posted on Nov 18, 2008
MFC7860DW PRINTER. USB CONNECTED TO DELL OPTIPLEX 380/ WIN 7 64 BIT. UNABLE TO PRINT. fax receiving data msg on printer display. Tried may fixes offered by Brother and other articles. Nothing works
'Unable to print' is to broad to know what's wrong.
You get a fax receiving data msg every time you try to print? Try reinstalling/updating the software.
The printing head moves as if it's printing and nothing comes out on the paper (I assume there is ink on cartridges) maybe the printer was sitting for too long and ink cristalized, going through several 'cleaning' cycles might fix it.
Hope it helps.
Dec 16, 2017 | Brother Office Equipment & Supplies
I think my printer is stuck in fax mode how to i start printing again
Leave it unplugged for a night and replug the maching. Go through the setup menu again and just try copying something. This should clear the fax buffer. Then retry the fax.
Oct 07, 2014 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
HP 5780 will not receive a fax.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } There would not be problem in phone line. please slect slect appropriate option in data fax mode.
slect it to the recieving mode.
hopefully it will work fine
Sep 03, 2009 | HP Officejet J5780 All-In-One Printer
Recived faxes only print out blank pages
Someone sent you fax upside down. If your machine prints and copys OK, it's not your machine.
Aug 19, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printing fax
take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Jan 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Jan 28, 2008 | Brother MFC-8220 Fax
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
