Question about Hotpoint NWXR473EV Dryer
Dryer CDT00 not getting any heat.
I have cleaned the filters on the machine + condensor, i have also cleaned the back of the machine. The drum is turning but im not getting any hot air into the machine, hope you can help.
Many Thanks
Dan.
  • Anonymous Feb 13, 2009
    I have a Hotpoint Aquarius CDT00 tumble drier. Everything works except the drier is not heating up. I had a quick look inside but can't see anything obvious. I don't have meters or testing equipment. Help?
    I have a Hotpoint CTD00 tumble drier which isn't heating up. Everything else is OK. I read about 'trip switch' but can't see anything obvious. Any help?
  • Hotpoint Master
  • 3,463 Answers
Suggest you check the heater and thermostat(s), to be found at the rear of the m/c behind a removable panel., you will need a meter to do this.
If o/k then problem could be faulty control or relay if it has one..
To be found at the top front.
Posted on Dec 13, 2008
Beko condensor dryer not emmiting any heat but still 'working'
Stat or heater check power if it is a 220 volt machine may have one side down on power
Dec 03, 2013 | Zanussi TC7102W Electric Dryer
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
My AEG Lavamat 16830 Washer Dryer does not heat up on the drying cycle. I comes on and after 15minutes the timer jumps to ) and the dryer stops. On opening the door the clothes have not been heated at all...
Had an identical problem with my 16830 washer dryer and noticed reading other posts that others have had this issue with 16810 units too. After reading posts about the 'condensor issue' causing clothes not to dry properly I got a socket set and took the back-half cover off the machine (11 screws/hex screws in all) to have a look. I then removed and cleaned out the accumulated fluff from the transparent plastic condensor unit. It didn't appear to have much fluff caught within it so I doubted that this would solve the issue.
Upon putting the unit back into situ I noticed that the temperature sensor in the large black flexible tube that connects the condensor to the drum had just one orange wire attached to it. I then noticed a second orange wire hanging loose nearby and putting two and two together figured that the loose wire had dropped off the sensor. Since the connector can't be rewired I resorted to carefully soldering the loose wire to the connector and ty-rapped both orange wires to the connector to prevent the wires working loose again. Once I had the connector back on the sensor both wires were pretty taut between the main wiring loom and the sensor and so I suspect that what had happened was that in normal use the wire had come adrift from the connector due to the drum rocking back and forth and pulling the wires against the loom - a design flaw I'd say.
To create more slack for the two wires in question I cut the ty-rap holding the main wiring loom to the side of the dryer and then re-fitted a new ty-rap in exactly the same place around all the wires in the main loom except for the two orange wires so that they remained free of the main loom to move as the drum rocks. With the wire back in place and everthing re-assembled the dryer heats up perfectly and counts down as it should.
I figured that with the sensor not operating the computer determined incorrectly that the air leaving the drum was too hot/dry as would be the case if the contents of the drum were completely dry and as a result the computer turned off and kept off the heater for the remainder of the drying cycle. I also concluded that as an energy saving feature - with the computer thinking the clothes are dry - the dryer speeds up the remaining drying time so that the drying cycle finishes sooner, hence why the counter completes sooner than it should and all with no error message.
Hope this is of help to others.
Jan 17, 2010 | AEG Washing Machines
Condenser dryer gets hot but cloths not drying and water drainer
Check The Ducting To Make Sure There Is No Obstructions Inside. Find The Outlet Outside Where The Duct Goes And See If Your Getting A lot Of Air. In Some Cases You May Have To Remove The Back Of The Dryer To Remove The Biggest Lint Ball In The World.
This Huge Lint Ball Builds Up Over Time And Quickly For Users Who Do Not Clean The Lint Trap On Every Cycle.
All Of The Above Will Cause The Dryer To Not Be Able To Get Good Air Flow Thus Causing The Machine To Have To Much Back Pressure.
Feb 04, 2009 | Candy DQW150 Front Load Washer / Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Cdc266 tumble dryer
hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
Aug 07, 2008 | Candy CDC266 Dryer
Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Mar 30, 2008 | Dryers
Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Jan 19, 2008 | Dryers
Dryers Logo
77 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
