Venta - Airwasher LW44 Air Purifier
Problem for Venta - Airwasher LW44 Air Purifier
My Venta Airwasher LW44 motor won't start
By tom0599 on Nov 16, 2008
When turned on, I can hear the motor but it won't move the fan part
Solution #1
posted on Aug 23, 2009
Not Rated)
Linda Banks
Rank: Master
Rating: 0%, 0 votes
Check to ensure the coupling is securely attached to the gear by following these steps.
  • Turn off and unplug the unit and spin the fan with your finger. Are the prongs/teeth are alternating from the gear? (moving)
  • If the prongs are not alternating from the gear, push the coupling into the gear and retest it. If the prongs/teeth are still not alternating from the gear, the life of the gear has probably been used up. (insert gear link)
  • If the prongs/teeth seem to be functioning test to see if the motor could be malfunctioning by hitting the "Go Back" button and selecting " Test the motor to see if it is working." option.
  • More help and parts located at www.ventahumidifiers.com
Comments:
Aug 23, 2009
- It could be in need of a gear box or a new motor. You can purchase both at www.ventahumidifiers.com
Was this helpful?
Yes
No
Solution #2
posted on Jul 03, 2009
Not Rated)
rickpepper
Rank: Guide
Rating: 75%, 1 votes
Test the motor to see if it works. Make sure the motor is removed from the rest of the unit. To find out how to remove the unit please hit the "Go Back button and select the "How to remove the motor button"...
  1. Plug the unit in to a working outlet.
  2. Push the #1 speed button on top of the motor.
  3. You now need to engage the saftey switch to start the motor.
  4. Protruding from the motor are two plastic about 3-4 inch guiding arms.
  5. Look inside the end of both of these two guiding arms. One of the arms are hollow and the other one has a white safety switch in the arm.
  6. Use a pencil or small item to push in on the safety switch.
  7. If the fan sarts to rotate the motor is still working.
  8. If the fan does not rotate then the life of the motor has probably ended and a new motor is needed. ( insert motor part link)
For additional support email abdistrsupport@gmail.com
Was this helpful?
Yes
No
Popular Solutions for Venta - Airwasher LW44 Air
Questions and Unsolved Problems for Venta - Airwasher LW44 Air
Do you recommend Venta - Airwasher LW44 Air Purifier?
Answer
Answer
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the... (More)
Answer
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I... (More)
Answer
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It... (More)
Answer
oreck xl tower air purifier red light for collecter cell stays on even after cleaning
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta - Airwasher LW44 Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
