Question about Whirlpool Dryers
Estates dryer by whirlpool has a 3 prong plug. the wall has a 3 prong w/an L shape. where can I get a wall switch to match the 3 prong without the L shape as this is a straight shape
  • 240 Answers
Home Depot, Lowes, etc will sell these type plugs in the electrical section. If installing yourself, be sure you get the wires in correct positions, let me know if you need info on that.
Posted on Nov 16, 2008
I recently changed the cord on my electric Whirlpool dryer from a 3 prong to a 4 prong. The socket in the wall is 4 prong and matches the new plug perfectly. However I cannot get the plug to go in all the...
Sometimes they do go in really hard and you have to almost hammer it in... use the palm of your hand and give it a good whack... it will go!!
heatman101
Jun 01, 2011 | Whirlpool LER5636P Electric Dryer
The dryer cord does not match my plug. is that cord required or can I buy another dryer cord and use that instead?
cord for dryer should be 3 prong and center being L shape or a 4 prong dryer corder with an L shape either one is fine aslong as its a dryer cord ,,,, donot put range cords on dryers they use different amperages and could trip your breaker and cause electrical overheating of wiring....
Jan 28, 2011 | Kenmore Elite HE4 Electric Dryer
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 | Dryers
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Conecting a 220w plug into a standar wall plug
If you are using an elctric ( not a gas) dryer then never try to plug the power cord of that drywr into a 220VAC wall receptacle. It isn't rated for the appropriate current that the dryer requires..However if yiou have a dryer that operates the contro system and is NOT a Gas dryer than you will need the proper plug end that matches the receptacle on your wall. Most harware stores should carry the right plug. I do not know what country you wrote your problem from and there are different power grids throughout. In general though, if you do have the right plug that matches your wall receptacle and it has 3 prongs... the two side prongs are normally the power and the disimilar prong is ground.. Can't help you with any additional details without knowing what you are confronted with..
Aug 31, 2008 | Dryers
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
