Question about Sony VAIO FR105 PC Notebook
Sony VAIO FR 105: It does not read CDs
My laptop has no problem playing DVDs but for a while it has stopped reading CDs (data/music/software/etc) spontaneously. Sometimes I have to tilt/hold the laptop at a certain angle/position before it reads the disc. I'm not sure this helps as the position of such tilt is not constant. It just fails to recognise the CD in the first place...I suppose the problem lies there but am not sure of what to do. Thanks for your help.
  • Anonymous Nov 16, 2008
    I can not play video normal
CD-RW/dvd drive can't read any cd/dvds
Which model VAIO do you have?
Dec 31, 2007 | Computers & Internet
My sony vaio vgn-n110g w/ pioneer dvr stopped burnning
Sounds like you may need a new drive. If I remember correctly those run about $100 and if you feel confident and read the directions (and research it correctly on the internet) you should be able to install it yourself.
Jul 01, 2009 | Sony VAIO VGN-NR160ET Notebook
Sony VAIO CR220E laptop DVD RW Drive is rcognising DVDs only not CDs-I reinstalled driver-Removed upper and lower filters-solve this- shaik Muneer Basha, muneerbasha_shaik@yahoo.com
dear friend
sorry to say that your dvd drive needs to be replaced,
it happens most of times
dvd drives of laptops arent of so much great quality
thanks
Apr 10, 2009 | Sony VAIO VGN-CR220E/P Notebook
My Sony Vaio FR-130 will read cds and will read DVDs that are not copyrighted but will not play dvd's that are copyrighted.
Try reloading the DVD drivers...If you don't have them on cd, you can download drivers from sony website. once you download drivers, reboot comp. see if that works...let me know.
good luck
Apr 10, 2009 | Sony VAIO Notebook
Sony Vaio with Vista has stopped reading Data CDs
make sure windows media player is not starting on boot up if it is running in the back ground it can cause simialar problems.
Feb 11, 2009 | Sony VAIO VGN-FS640W Notebook
Reads and writes cds,reads dvds but does not burn dvds,
This drive is normally supplied with a couple of Dells.
(because of compatibility) Inspiron 700m,710m
If you have another machine for testing?
check the disk for contents to see if the data burn happened,
this will explain a few things in your processes.
Uninstall/Reinstall the drive and reboot then try again.
Have you tried a full system reinstall yet?
Did it fix your problem?Please let me know thanks
Jul 15, 2008 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
DVD unit doesn't read CDs but works fine with DVDs
Sir: Did you try another CD or just 1 CD could not read by your DVD RW? Would you please make the DVD poped out and re-set it again. It seems the problem of communication becasue the code rate of DVD and CD is different. Its not related with the lens.
Jul 20, 2007 | Sony VAIO PCG-K35 Notebook
Sony VAIO FR105 PC Notebook Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
