Question about Canon BubbleJet i560 InkJet Printer
Pictures printing with green tint
When I print pictures, they have a green tint to them. The ink cartridges are all correct, I've changed them all. I've tried filtering it out without any luck. I am so frustrated that this printer is about to head out into the garbage heap HELP!
Aoryu
  • 3 Answers
SOURCE: canon BJC 3000 does not print - 6 orange 1 green
Clean the connectors located on the Printhead and the Printhead Carrier... It solved the problem in my case...
Posted on Aug 13, 2008
gwbm
  • 353 Answers
SOURCE: shows replaced cartridge as empty
The cartridge chip needs to be reset to "full"; for this you need a chip resetter - this should have been done by whoever refilled the cartridge for you. You can get your own Epson chip resetter very cheaply on E-Bay.
Please rate this solution if it is of use to you
Posted on Feb 21, 2009
  • 291 Answers
SOURCE: Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Posted on Apr 03, 2009
ghassun
  • 499 Answers
SOURCE: Brother mfc 240 c Will not recognize G&G Ink cartridge
try to clean the pinout of ur cartridge and of ur printer cartridge mount with acetone
Posted on Jun 08, 2009
ThiruBulls
  • 103 Answers
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
Yellow ink doesn't print from the cartridge.
Try to change ink jet cartridge with a new one from hp and then blow off the contacts with compressed air. Make sure the tape is removed from the nozzles of the ink jet cartridge before installation.
Good luck on this repair.
Feb 09, 2011 | HP DeskJet 970cse InkJet Printer
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Every picture has a green tint
The magenta ink is not working, clean your print head through the software in your preferences and see what happens, If your pictures show no sign of improvement, clean a second time. If still no improvement, than either your magenta ink is empty or faulty or the print head is faulty. As it is a HP, both the head and cartridge are one in the same, so replace the colour cartridge and you should fins your pictures will be perfect again.
Gremlin11
Dec 13, 2008 | HP Photosmart D7260 Printer
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Green Tint Over Entire Printed Picture
I had a very similar problem and found out that the problem was the quality of paper I was using. Remember, a photo printer is expecting high quality results. Cheap, low quality paper will not accept the ink as well as higher quality paper. I can't guarantee this will solve your problem but I have not had any green tints since switching to a higher quality photo paper.
Jun 27, 2008 | HP Photosmart 8150 InkJet Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printing in green
Sounds as if one or more colors is out/dry in the ink cartridge. Have you tried a new cartridge or cartridges?
Jun 19, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
109 people viewed this question
old marine
old marine
