Question about RCA LCDX2328WD 23 in. TV/DVD Combo
My lcd tv takes a long time to come on
I have a HD50LPW175YX7 RCA TV. When I turn the tv on the light grid on the bottom of the tv starts flashing. It goes thru a series of the grid lights flashing without the tv comming on. I had to turn on the tv approx 5 to 6 times this mourning before the picture would come on. This is the sceond time this part has gone out. The first time I took it to a repair shop ( aprox 1 year ago ) to have it fixed. Now its doing the same thing. Im looking for help in finding the part that starts the bulb. Once the tv comes on I have a great picture. Going thru this for the secong time its only a matter of time before the tv will not come on at all.
  • RCA Master
  • 19,396 Answers
When the TV stays on protection with the led on and blinking for a while , then suddenly turns on, that is oftem because of a faulty power board.
Posted on May 05, 2009
  • avianforde Nov 20, 2010
    can that be repaired
L32hd31xy12 sound but no pic
Your tv T-con board is defective.
Apr 01, 2015 | RCA L32HD31 32 in. LCD HDTV
Need remote code for an RCA television
I have had several remotes; 1 was RCA. Resetting the remote was the same on all - 1. turn TV on, 2. press and hold code search button until light goes on (some flash, others stay on), then release 3. press TV button, release once light goes on 4. press on button every 10 seconds or until TV turns off - up to 100 times pressing button!! 4. press enter . Now the test... turn TV on - good luck
Jan 02, 2013 | Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
My new LG LCD won't turn on
Take ur waurenty repair the tv is faulty.The LCD inverter board is shorted.Need it replaced,not lighting ur LCD backlight screen to get the picture.
May 01, 2010 | LG 47SL80 LCD TV
Rca 32 inch hd tv wont turn on
Josh,
Take your unit to a service center where they repair tv in your city.
Ask them to repair it. Because there are no repair manuals they will not repair.
Make sure they use a work order. when you pickup your tv.. make sure you get the work order or a copy.
With that order... call 1-877-297-8391 and get a new tv
Apr 11, 2010 | RCA L32WD22 32 in. LCD HDTV
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Nov 20, 2009 | RCA L42WD22 42 in. LCD Television
Volume not working for different tele
Hold down TV button at top of remote until other buttons on top row light up. Press red power (big one) then press channel up repeatedly until tv turns off. Press # button on bottom right to set the new code.
It might only take a few channel ups before you find the right code but it may take a hundred. If you go thru all of the codes in the remote the tv button will start flashing quickly to indicate you have done so.
When you are all finished just remember to press and release the sat button up top to control the Dish receiver once again.
Here are some common brand name tv codes also. If yours is here its easier to enter the code. Hold down the tv button until all others light up then enter the three digit code and press #.
Sony 500 Zenith 501 RCA/GE 503 Mitsubishi 504 Panasonic 512
Aug 21, 2009 | Televison & Video
RCA LCDX2328WD 23 in. TV/DVD Combo Logo
1,150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
