Inglis top load washer smells
Hi There,
I thank you for this site to start with :) Can you please help , my washing machine smells like rotten eggs I wondered if there is a filter at the back that can be cleaned. We have hard water in our area with water softener used but, still get scale. If I have explained it clear enough, is there any advice that you can give me.
Thanks in advance
  • nyree71 Nov 16, 2008
    Thanks for the reply, I will let you know how I get on. Is there a filter behind the machine?
  • nyree71 Nov 25, 2008
    thanks everyone for the help, it was clear when agitator was removed
Hi Nyree,
Check the center of the agitator, where you add softener.
Remove by pulling up. It will be full of old softener.
It may be necessary to remove the whole agitator ( set screw on bottom).
The inside also gets full of old softener.
Good Luck.
Posted on Nov 16, 2008
  • the4neffs Nov 25, 2008
    Hi Nyree,
    If there is a filter, it may have been added as an accessory. It is not part of the wash machine itself.
    At least I have never seen one before.
    Peter N
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
My amana top load washer is foaming out of the discharge
sounds like you need to clean your washer , use white distilled vinegar about 2 cups on a heavy hot wash and if you are still foaming you can use vegetable oil to remove suds , repeat if needed
Feb 17, 2013 | Amana Washing Machines
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer won't come out of final spin, have unplugged and plugged back in
I have the SAME PROBLEM! And it smells like rotten eggs. Both of these poroblems occurred together for the first time today.
Aug 04, 2010 | GE WBSE3120B Top Load Washer
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Front loading washer
it could be that your motor in the washer could be blowin or your belt
Feb 11, 2008 | Kenmore 24832 Top Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
409 people viewed this question
Top Washing Machines Experts
