Question about Aiwa Z-VR55 Shelf System
Cd drawer keeps opening and closing
The cd drawer keeps opening and closing no matter what i have selected as to tuner, tae, or cd.
  • xfurrier Apr 07, 2009
    A similar problem with my panasonic hi-fi. The CD tray opens regardless if it's in radio/tape/cd mode and stays open. The system is (a pretty old) Panasonic SC-PM25.
2 Suggested Answers
revskank
  • 203 Answers
SOURCE: CD door will not open. Does not respond to the open close button.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Posted on Mar 16, 2009
How do I fix drawer on Azur 640 CD player?
Might be as simple as cleaning the lens
Aug 07, 2016 | Audio Players & Recorders
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Hi, Well i had the same problem with my CD drawer.Your CD drawer has some problem. Either repair it or buy a new one.
Thanks1 Sandy
Apr 21, 2009 | Gateway GT5220 PC Desktop
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Aiwa Z-VR55 Shelf System Logo
75 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
