Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
Too much salt
My dishwasher is about 18 months old and has not been very good from new. However it has recently started using a lot of salt which gets left on the dishes after the machine has finished - not visibly but you can taste it! I have checked the top rack and for blockages in the upper and lower spraying arms (thanks to Lapin for the tips). Filters have also been cleaned (as they are regularly). Unfortunately that doesn't seem to have worked. The other sympton that has developed is a "sucking" noise when first switched on. It sounds a bit like a pump that is trying to work without any water in it but I could be wrong. Any help would be gratefully received.
    New Friend:
  • 67 Answers
Re: Too much salt
Don't know about this model, but if the salt pickup is inline with the water the water may not be flowing in fast enough and the reduced pressure may be letting the salt in. Anyway, final rinse should remove the salt. Try putting two clean glasses (no salt taste) in the unit, one upright and the other down. Run the unit with no soap and stop it after each cycle and check the glasses for salt. If you still have it after each cycle, try filling the unit from the sink manually before the final rinse. If salt's still present, something's leaking
Posted on Nov 30, 2007
0 characters
3 Points
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
18 inch dishwasher
I've never heard of dishwasher salt. 2 kg is about 4-1/2 pounds worth.
May 06, 2014 | Dishwashers
18 month old kitchen aid kudc10fxss leaks water at bottom of door
Someone may've accidentally put liquid dishsoap rather than dishwasher soap into the fill cup. The bubbling will cause lots of foam to rise up above the float-switch without actually raising the switch (shutting off the water supply). Lots of helpers on the web recommended draining, wiping out the foam, pouring in a cup of vinegar and a handful of salt and running the rinse cycle a couple of times. It worked for me!
Feb 25, 2013 | KitchenAid KUDC10FXSS - KitchenAidR...
My Beko 5411 dishwasher will not start it's cycle
There will be something stuck inside the drain pump, You only have one issue, as it is only 2 months old opening it up to unblock may affect your warranty but it's not a problem covered by warranty so they will charge you to fix it, if you decide to try yourself you need to remove the kick panel and you will be able to see the drain pump, you need to unhook it and remove the blockage from it.
Mar 05, 2012 | Beko DE2541FW 18 in. Portable Dishwasher
No salt used
they dont use a lot of salt, but take the top off the salt compartment and with a long handled spoon give it a good stir up be quick or it will start to come out.
Jan 20, 2010 | Neff 24 in. S4443 Built-in Dishwasher
Milky residue and a dry salt pot after each wash
It sounds as if there is a blockage in the salt matrix / inlet. This can happen if the wrong type of salt is used.
The simple answer is to use the expensive tablets/pods - that include salt. This will improve the wash and hopefully the blockage will free eventually.
Fill the salt container with water regularly to try and help dissolve it - no salt untill it's clear.
If it doesn't clear within a month - it may need stripping and clearing manually - or continue with the premium tablets untill something else breaks - requiring a service.
Aug 28, 2009 | Zanussi 18 in. DE4744 Free-standing...
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Aug 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
The salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Mar 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
1,273 people viewed this question
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
