Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Double image I have an huge old TV that we love. 60FX32B. It has a great picture most of the time. It goes out of focus, double image in red at times. Seems to be happening more often. Could playing video games on the TV have messed it up? To replace this size TV will cost $4000. I'd like to repair it if possible. Any ideas or is it junk? Thanks so much!
  • 1 more comment
  • cwwol Dec 03, 2008
    Since writing this we have found that if we hit the back of the TV it will go into focus for awhile. We then were able to adjust the convergence. It doesn't last very long though. Is something loose or do we need to replace a part?
    I failed to mention this is a Hitachi.
  • cwwol Dec 11, 2008
    I need some help finding the parts that need soldered. I looked at the pictures provided but my set is different. We opened it up and dust everywhere. We cleaned it out and it was good for a short while then the problem returned. It still clears up when you hit the back. p Do you know where to find them on the 60FX32B?
    Genius:
  • 1,239 Answers
HI The problem sound like the fluorescent bulbs that lite up the screen are out. Keep in mind that there are many, many fluorescent bulbs in the panel and only a couple or out.
Posted on Dec 03, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 03, 2008
    Usually when the OSD will not come up, you are looking at a problem with the video boards. Is the power button flashing or showing a different color, or does it look normal in the On position. If it's flashing, then the problem lies with the mainboard not powering up properly. It might not hurt to try a power drain at least:
    1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
    2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
    If this doesn't work, the TV will likely require service.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description a most likely convergence issue. If aligning would not merge the video signals, then it is probable that the convergence circuit has to be checked. Since the problem is intermittent, then one could deduce that it is a loose connection or most likely, a cold solder. Re-soldering should address the problem. Of particular interest would be the pins of the two (2) STK392-110 or 150 ICs and resistors within the immediate area.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • Hitachi Master
  • 13,433 Answers
You possibly have a convergence ic problem and the chips would need to be replaced..
Heres a Very detailed guide on the subject
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
  • Ekse Dec 03, 2008
    It is basicly the same process, you need a service manual, you will find the details of the convergence ic's in the service manual, and you can purchase the parts, and then replace them, with the help of the above guide.
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 42 inch ultra vision has double image
it is just a convergence problem which makes the image look doubled.it can be repaired by any good local tv technician for approx 75 to 80 dollars.nothing much to worry.
Dec 01, 2008 | Hitachi 60V500 60" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Hitachi Mo# 53uwx10ba double image
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
