Question about Nvidia GeForce4 MX 440, (64 MB) Graphic Card
Graphics card problem
Hello sir ,
I have a nvidia graphics card GE force 6200. recently i am having a strange problem. as soon as i switch on my computer , the display flickers and when i go to my computer the drives appear as if it is smudged and display is very dull. First i thought it may be because of my monitor .but when i removed my graphics card , the display becomes normal. and also when i was using my graphics card and whenever i put my system into standby mode , it would automatically come out of standby mode without moving the mouse. Is it something related to drivers.Do i need to install the latest NVIDIA drivers.
My configuration is as follows:
Intel P4 2.66 ghz
Intel D101GGC motherboard
512 Mb ram
Samsung syncmaster 591s Monitor.
  • shankar08 Nov 17, 2008
    The refresh rate is 60 hz and no other option is available . There is a check box(hide modes this computer cannot display) below that. If i select that , then i can select 70 hz and so on upto 100hz. but when i select anything greater than 70 hz . i get a blank screen and a hz symbol is shown on the screen. Even if i select 70 hz , the screen is again blurred and dull and flickers.
  • Lou Labetti
    Lou Labetti May 11, 2010
    Do you know what the refresh rate is set at? if you do not know what that is please get into your control panel click on display - click the tab settings, the button advanced, click on monitor and tell me what you see.
  • 42 Answers
Hi......
all u need to do is to set up the screen refresh rate to default and always keep ur graphics drivers up to date
Posted on Nov 18, 2008
My nvidia graphics gets heated very soon...while running crysis games..is it normal?
Hi complicatedt,
Yes, it is normal, that's why graphic cards nowadays has it's own cooling fan.
The heating of the cards also depend on the system requirement of a program or game.
Hope this will help you.
Thank you for using FixYa!
Oct 07, 2011 | SIB 256 MB FX5500 NVIDIA Geforce Ge-force...
We reinstalled Windows and now there is no "Display Adapter" in the device manger listing and the display is not right. I think we are missing a driver for Nvidia GE Force 6200 turbo cache card....
Please check if you have an onboard display card and the NVDIA GEforce card, this situation can hapen when you connect your monitor to the onboard card instead of the NVidia card and try to install the driver for NVIDIA card.
Connect it back to the NVIDIA display card and once again install the downloaded driver, it should identify the device and install fine.
Feb 03, 2011 | Computers & Internet
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
Which is better, the NVIDIA GeForce4 MX Integrated GPU or the NVIDIA GeForce 6200?
The 6200 has dedicated memory and being a several years more recent design is easily the better of the two.
Oct 04, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Need advise for upgrating graphics card
GET THE NVIDIA G FORCE 8400 GT IT IS THE NEWEST CARD AND IT WILL RUN EVERYTHING YOU HAVE.
Mar 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
install the latest drivers mate
or
your gfx card has gone bad, if its under warranty you'll get it replaced for free.
Dec 25, 2008 | ATI 3D Rage LT PRO, (8 MB) Graphic Card
Shankar,
I looked up your Monitors specefications to try to confirm my theory. Which is that this is a resolution problem. Your Monitor is rated for a maximum resolution of 1024 x 768 at 68 Mhz so this is the max that your Video card can drive this at. However with a CRT Monitor running them at their MAX for extended periods of time can lead to the fuzzyness your talking about. Its likely that when you switched it to the On board or secondary videocard that it defaulted to the standard SVGA display levels of 800 x 600 resolution. Allowing the Video card to increase the refresh rate to 85Mhz.
Which coincidentally is what the Samsung recommends as the optimum setting for this monitor so I believe if you scale down to 800 X 600 @ 85Mhz I think this will clear up your problem. Though if your like me you like to maximize your screen real estate as much as possible.
There are alot of monitors in the market for around $100 USD that have "Native" resolutions of around 1280 X 1024 @ 75Mhz
Hope this helps you
Dave
Nov 17, 2008 | Computers & Internet
XFX Geforce 6200 256 DDR RAM
i have found that some boards don't like Nvidia graphics cards and play up when it comes to a particular graphical attempt. You can try the game and card on lower settings, but that defeats the purpose of the card, and make sure you have the latest directx (9C i think) installed You can try as i did some older graphic card drivers for your model as Nvidia now seem to make generic force drivers for all models. I had luck with different drivers for a while, but ended up buying an ATI graphics card and as of yet after a year had no graphic problems.
Apr 25, 2007 | XFX GeForce 6200 Graphic Card
Nvidia GeForce4 MX 440, (64 MB) Graphic Card Logo
217 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
