Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Brushes do not rotate, cannot turn square fitting that spins brushes - does this unit have a belt to replace or how do I see what is drving the brushes.
  • alyonso Feb 09, 2008
    square shaft from middle brush has broken in half .the part #36418-011 that contains the 5 brushes is in good working order.can i purchase just the middle brush with shaft or the unit with the brushes complete.whereis my closest dealer in kamloops b.c. canada v2b1w3
    President:
  • 1,673 Answers
There is no belt, sounds like the turbine is bad and will have to replaced.
Posted on Jan 06, 2008
Hover f7458-400 carpet cleaner brushes wont turn
Based on the hints above I cleaned the filter as it was clogged. That did not fix it. Then I took a stout screw driver and used it to turn the square brush drive, The drive broke loose and I am in operation with no dis-assembly. Hooray!
Apr 22, 2012 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Where is the belt on a hoover agility?? My brushes stopped spinning and I think that the belt broke but I cannot find it
If you have the manual it should show the location of the screws or clips that hold the cover on for the belt.
Dec 03, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't roate
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Oct 03, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility
I don't believe there is a belt, check the brush block and make sure that the shaft isn't broken off, if ok, then the turbine is bad and will have to be replaced.
Jan 05, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
388 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
