Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Comfort glo propane ventless heater won't light
Just got a used heater, person said it worked fine. Put new battery in the igniter, It sparks fine but won't light. Can't hear any gas coming thru. Checked most obvious on off valves to and from the gas line. Nothing obvious. Had a professional in to hook up the gas line and made sure the line is turned on.
Did we get ripped off? Or is there a way to fix it. Thanks in advance for any help.
  • 1 more comment
  • oblivia Nov 17, 2008
    I think i have the same problem...but it's a gas version that came with my house, so i don't know if same applies...it says glow-warm on it and otherwise looks exactly like the picture that comes up on top of this post. I don't have the manual, but i assumed turning the knob to "pilot" and making a spark with the igniter should start it up, but the pilot does not seem to light, nor does anything else happen. It's apparently a fairly new installation and was allegedly in working order, so i am curious as to whether i may be doing something wrong. Don't hear or smell gas either. I'm kindov afraid of it, and am cold!
  • need some he Dec 07, 2008
    My heater is doing the same thing. I have done what solution #1 says to do. I can get it to ignite,but it never goes ahead and lights the whole row of flames. It's not because it's warm in the room. It nows says it's 50 in there!
    Any other ideas?
  • Anonymous Jan 11, 2009
    I have the gas comfort glow model and the pilot lights and stays lit. This model is run by a remote (All batteries are new and dials are set correctly) I hear a small click when I go to ignite the main heating unit however the gas does not turn on to the unit. Is there an override from the remote or do I need to replace something? This unit is less than 2 years old.
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Posted on Dec 06, 2009
Most likely the oxygen depletation sensor has failed. When it fails it cuts all gas flow as a safety precaution. Because the sensor is built into the gas flow control it is not servicable and requires a replacement. These are the weak point on all ventless gas heaters and fireplaces. I have found it easier to trash the heater than to replace the failing part.
Posted on Dec 04, 2009
You have to turn it to pilot hold it down for one minute then push the ignitor it should light then turn it to the setting you choose and the heater will go off when it reaches the temp and come back on when it cools down always leave the pilot lit.
Posted on Nov 20, 2008
My solution that I have is, the comfort glow heater puts off an odor; we have cleaned it when we lite it for the winter. The heater does come on and will stay lit, but the odor is uncomfortable. What can be done about the odor?
Posted on Dec 31, 2012
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I have a dyna glo 30,000btu lp ventless wall heater. I know it needs the ingniter replaced. I have tried to light it by hand and can not. It seams like their is know gas getting thru,is this possible
yes you have to get the thermo couple hot in order to get the gas valve to open to ignite the main flame
You are probably trying to light the main flame and not the pilot
light
Hold the pilot light button down and put flame to the pilot light opening
You need to be very careful depending on the type of flame you are using to light with the thermocouple could get hot enough to open the main burner flame and it will ignite
I suggest replacing the igniter rather than doing the above step
Oct 13, 2013 | Dyna-Glo Heating & Cooling
Pilot will not stay on
replace your regulater,which almost cost as much a a new heater.I have own 4 or 5 and finally got a good one,I have in the past cleaned out the regulator that was plugged with oil from the propane,they put oil in the propane for leak detection,I hope this helps you
Dec 02, 2009 | Mr. Heater (F274825)
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Jan 11, 2009 | Century Tool 2320I Heater
Dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Mar 12, 2008 | Heating & Cooling
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
4,367 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
