Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 60pp9202 I have a bow in my picture and color is still off a bit on the green side.I changed the 2 stk ic and now I can line up the plus marks but color still not all the way good
  • Philips Master
  • 3,459 Answers
Did you replace the Convergence Resistors at the same time?
If not you need to replace them also.
Posted on Nov 18, 2008
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts. Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
I have a Phillips projection TV Model# 60PP9202 Chassis # DPTV305F with a linear distortion problem. The colors are not aligning. Can I fix my TV myself, or do I have to take it in. Any advice would be...
It soundsa like you have a convergence problem. Probably only one color. (The green and red may be ok but the blue is bowed or any of those combinations) This will require the repklacement of convergence IC's and then alignment. Probably best to have a experienced tech take care of this.
Nov 26, 2008 | Philips 60PP9202 60" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
