Question about Kitchen Ranges
Jenn-air stove temperature not constant
1994 jenn-air slide in range. The oven temp has a wide degree swing.
The oven is about 80 degrees off to the cold side. I can set the temp up abur 80 degrees and it will reach set point 80 degrees lower. Then the temp will vary 50 to 60 degrees. The cook top cooks great but the oven will not hold temp
  • 240 Answers
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
Posted on Nov 16, 2008
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Jenn-Air Gas Oven Too Hot
Hi and good morning too you. First of all the normal oven swing is about twenty degrees, so your swing of thirty up is ok. I would center the swing, bake button, should see the offset screen. Change the setting to -10 and try again to check you temps. This drift you have is ok and by changing the offset should able you to control your overheating issue and center your swing.
Good Luck, feel free to ask for more help if needed.
Dec 06, 2013 | Jenn-Air Ovens
Jenn-air refrigerator too cold
what are your temp control settings frrzer should be about zero and fridge side should be around 39 degrees temp. try setting it lower maybe 3 if control knob if digital check for 39 to 40.
Oct 21, 2013 | Jenn-Air JCB2285KES (21.5 cu. ft.) Side by...
My JENN-AIR oven will only heat to 250 degrees.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 06, 2011 | Jenn-Air SCE30600 Slide-In Electric...
I have a Jenn Air JGS8750 Gas Oven. When I turn on the oven and enter a temp setting..the oven after a few seconds changes it to 100 degrees. Seems to be defaulting to 100 degrees.. Any ideas what the...
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 14, 2011 | Jenn-Air JGS8750 Gas Kitchen Range
Oven will not maintain tempature with what was programmed
You might try calling Sears, or wherever you purchased the oven. Or even an appliance repairman. It sounds like the oven temp needs to be re-calibrated, or buy a thermostat to put inside the oven and follow the temp it says.
May 31, 2010 | Jenn-Air JES9860 Electric Kitchen Range
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
201 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
