Question about Hotpoint Ultima WF860 Front Load Washer
No heat hotpoint ultima lodgic sensing condencer dryer TCM65,,everythings working accept no heat please can you avise wot to check and erplace meny thanks keith
  • Keith Knott
    Keith Knott Nov 16, 2008
    ive just been out a got a mulitimeater 2 check foe continuity {how}
  • 135 Answers
First thing to check are cutouts located above element. Should have continuity on both. take care element is fragile. Some models have a third located in the door space although this one is rarely prone to fault.
Posted on Nov 16, 2008
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint tdc 30s condencer tumble dryer does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 03, 2011 | Hotpoint Dryers
Hotpoint Ultima TDC 60 P. Condenser dryer. Everything works but no heat. I have taken back off and replaced the heater but still doesn't work. Any suggestions please .? If another part is required could...
Sounds like on of the thermostats have gone bad. You will need a multimeter to test them for continuity. Here is a link to the parts you may need. This is a video to show you how to do it.
Hope this helps you!
Nov 26, 2010 | Hotpoint Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
My tumble dryer has stopped heating up its a hotpoint tcm65 the dryer powers on and spins correctly but the drying light does not come on at all and the dryer doesnt dry!! please help!!
Friend,
ngfam1 At your service!
Sometimes this can happen when the vent line is clogged.
1. If the dryer is gas and old, the pilot could be out or if it is newer it could have a defective or worn out a igniter!
2. Check if the lint filter is full and needs to be cleaned.
Try this first.
3. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 30, 2008 | Hotpoint Dryers
Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Jun 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
209 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
