Question about Maytag Atlantis MAV6000 Top Load Washer
Small items stuck under the agitator
I need to remove the agitator to remove these items. On old washers you could easily pop off the agitator but I can't figure out how to do it on this model.......any suggestions???
    Genius:
  • 2,920 Answers
It should have a cap on top with a bolt underneath it that you can take loose.the top of the agitattor should pop off
Posted on Nov 16, 2008
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
Dec 19, 2013 | GE Washing Machines
I have a new Hotpoint washer (top load) model HTAP1200DWW i have a string stuck under the agitator. I removed the top cap on agitator but there's another plastic cup a little lower down the shaft. My...
Most just pop out. If you can get your fingers from both hands at 3 and 9 o'clock under agitator and pull up quickly and firmly, it should pop out.
Aug 25, 2017 | Hotpoint Washing Machines
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Clothing stuck under agitator
The agitator pops off. You will need to use a flat head screw driver or something short enough to get in the tub and under the agitator and it will pop off. They are on there pretty good so it will take some work
Jun 01, 2009 | Fisher and Paykel WL26CW2 Top Load Washer
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Jan 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Need to remove agitator
Check on the side of the agitator on the lower half for a small set screw. It's hard to see but you can feel it. remove this screw and the agitator should come out.
Dec 01, 2008 | Kenmore 22422 Top Load Washer
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
