The flickering picture usually indicates that the power supply is failing. The most likely cause of the power supply failure like this is capacitors either drying out or bulging from over heating. We have a page on our web site at:
http://www.ccl-la.com/blog/index.php/capacitors/ This article wexplains what capacitors are, what you will need to look for to identify the failures and which brand and series to get tof rht replacements. In most cases you can open the monitor and look over the power supply and see obvious bulging on the capacitors that are failing. If you replace them you should be back in business. If you have additional questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
