Machine wont aggitate,supplies water then sits,can sometimes
Drain+spin if moved to final rince
  • 240 Answers
Dont know what type of unit you have, but that usually means that you have a timer that is going bad, or has already went bad. You can also have a bad water level pressure switch, which shuts the water off, but doesnt send a signal to the timer. Both are located under the console.
Posted on Nov 16, 2008
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Wont spin
you have to check all the harness connections on this machine and when you realize that this is going to happen often you may want to consider tossing this in a dumpster.
May 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
