Question about Plumbing
I have a water pressure problem with a Grohe Lady Lux Cafe faucet
It is 4 years old & worked fine. A year ago, the pressured slowed and I removed the strainer at the end of the faucet. I also cleaned the small holes at the end of the faucet. It worked fine until now. We do have hard water, but the pressure is fine throughout the house. (The valves below the kithen sink are wide open. Is there another strainer inside the metal hose or at the ''bottom'' end which can be blocking the water flow?
I solved the problem by unscrewing the part of the handle which attaches to the "pullout" braided cord. There was another strainer in there which has some debris which was blocking the water flow.
John Was.
Posted on Nov 20, 2008
My Grohe kitchen faucet pressure is terrible, I believe I need to replace the screen. Can you help
Not sure if you fixed this yet, but I know that this faucet has a flow control option on it that you might want to adjust.
Dec 29, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a grohe ladylux that is almost 3 years old. the water pressure is low. When i unscrewed the head water flows well, but when the head is back on it rens slowly. I,ve cleaned the screen by unscrewing...
On this particular faucet you may not be able to reach the part that might be giving you issues in the spray head. However, to take the head apart, on the spray face you will turn it counter clockwise, the aerator will come out at that point and you should be able to see down into the tube to see if there are any obstructions. Also if you are using the little Grohe water filter that goes into the handle before attaching the hose, it is possible that that is clogged especially after 3 years. You should be able to remove that altogether, or contact Grohe for a replacement. If once you have removed all of these and have found no removable obstructions, then the only other thing to do is contact Grohe for a replacement spray head which I believe they are still available. Hope that helps.
Aug 18, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Lack of Water Pressure
If you have the spray head type, I had the same problem...called Grohe. They said to remover the pressure regulator. Take off the spray head, and just inside the end where the water comes in, you will see a white plastice thingy. Remove it. They said you can do it with needle nose pliers, but I had to pry it our with a tiny screwdriver. It came out in pieces, but once out, the water pressure is GREAT!
Mar 07, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Feb 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Oct 11, 2008 | Plumbing
Plumbing Logo
270 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
