Question about Rowenta Commercial Garment Steamer - White
Water does not transfer to boiler in Rowenta IS8100 steamer
Steamer heats. I can pour water into the boiler from the hose outlet end, and it produces plenty of steam. However, when I try to run the machine normally, no water transfers from the reservoir side to the boiler. I've descaled with vinegar several times- including pouring it into the boiler side through the hose outlet opening.
I am getting ready to take this apart (costs too much to ship to repair site and then pay for repair and ship back). Will I find a check valve, or is this a simply gravity feed where the liquid in the boiler chokes off the feed until enough steam escapes that the pressure drops and allows in more water? (I.e. is this an open path?) If it is an open path, I'll ge3t a long pipe cleaner or wire and open the path. But, if there's a check valve in there, I don't want to damage it this way. Rowenta Cust Support would not tell me the answer to what is in the liquid path.
Can someone help me understand the liquid path design, so I know what to expect? I hate to take this apart if I don't have to-- I've got plenty of other things I'd rather do with my time!
Thanks!
-- Heidi
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
DiYerTech
  • 70 Answers
SOURCE: Rowenta Steamer
I am not sure what the problem is, but Rowenta recommends that you use only clear or filtered drinking water only. Make sure to remove the reservoir and use the burst of steam to empty it out completely. When cool, access the steamer drain hole and fill and flush the tank over the kitchen sink or use the cleaning kit following the instructions. After a few of these use and purge cycles the system should be clean in a few weeks.
Posted on Jul 26, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Posted on Dec 30, 2008
  • 26 Answers
SOURCE: Is there a product to run through a rowenta pro
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
Posted on May 19, 2009
My Rowenta dg5030 is not producing steam. The iron plate gets hot and the boiler is hot. Just when you depress the steam button, nothing comes out. There is steam in the boiler. Thank you
The small transfer water-line to the steamer section has closed up. This is due to contamination of salts, accumulated calcium or other debris. Its baked on and not easy to remove. All I can tell you is: always use filtered water or distilled water in the NEW IRON that will replace this one.
Feb 11, 2018 | Rowenta Irons
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - Silver Mod. IS8100
So is difficult to say. The best way is to take the electrical iron and see with the person, What can they do . Otherwise you must investigate in Internet if there are some catalogue or parts available with photo and take it , and get it as sample for the repair shop.
God bless you
Jan 25, 2013 | Irons
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER PRODUCES STEAM. WHAT MIGHT BE WRONG AND HOW CAN I ATTEMPT TO FIX IT?
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Dec 04, 2010 | Rowenta Commercial Garment Steamer - White
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta commercial steamer
CLEANING
to water and use.
descale.
water.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
89 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
