Question about LG WM-1832C Front Load Washer
Lg 1832cw Thank you your response to my problem with worn bearings in my wm 1832cw. I went ahead and was able to do it myself (stubborn what can I say) I posted what I did,but I do have one question for you. should I have used any type of glue on the bearing seal where it comes in contact with the plastic tub? I did not, but wanted to. thanks Mike ~yfive~
  • codeba Nov 23, 2008
    I have the same problem. Yfive, what did you do to repair it yourself. I'm good at mechanical things and can probably fix mine as well.--CDB
Mike, you don't need to yse any glue cause it is a press fit bearing. I had to do the same thing. I was able to go to my local bearing supply for replacements. And it was much cheaper that going to an online place to buy them. It pay s to search.
Jim
Posted on Feb 24, 2009
Why does my lg front loader washer wm-1832cw sometimes give anle code and sometimes works
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
Jun 03, 2011 | LG WM-1832C Front Load Washer
Start/pause button doesn't work
I had this problem with another model LG washer dryer and the problem was just the tiny switch (6mm x 6mm) on the circuit board had worn out. They cost about 30 pence on eBay and are very easy to remove and re-solder onto the circuit board as there are only 2 pins. This saved a huge amount of money for a new control board.
Oct 13, 2008 | LG WM-1832C Front Load Washer
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
Spin cycles are becoming lowder and lowder
Tub back bearing or motor bearing worn.
the tub back seal has probably leaked and dried out the bearing
Mar 17, 2010 | LG WM-1832C Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
Small ammount of water leaks at bottom of door during wash
I have this same problem. What I do is carefully clean the part of the glass door where it meets the rubber gasket when you close the door. Bits of crud tend to accumulate there and break the seal between the smooth glass and the rubber gasket. This causes small amounts of water to leak out.
I don't use an abrasive cleanser. I generally clean it when it is dry and crusty with my hand or with my fingernails if it stubborn. You don't want to scratch the smooth glass surface. fingernails are much softer than glass and won't scratch the glass.
I also take a look at the rubber gasket and see if there is any crud sticking on that and very gently clean it off when it is dry and crusty. If the gasket gets torn, you'll probably need to replace it. I don't know how much that would cost. This should stop the dribbles.
Cheers,
Zac
Jan 11, 2009 | LG WM-1832C Front Load Washer
Bad bearings on front loading lg washer 1832cw
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks.
Nov 12, 2008 | LG WM1814CW Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
LG WM-1832C Front Load Washer Logo
392 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
