Sony KV2680R Console TV with bad color
I have a Sony KV2680R Console TV with bad color. It is all washed out in purple. The remote is also shot. I was wondering if it is possible to get a new TV replaced into the cabinet or if it is better to take it in for repair.
make sure no magnets, (speakers) are close to tv.
Magnets attract the color. TV's used to have to be manually
"deguassed"(demagnetized) Look for magnets placed close to TV. Speakers have magnets in them. It might save you a repair bill.
Posted on Jan 30, 2008
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
Posted on Apr 11, 2008
  • 4889 Answers
SOURCE: Sony KP 57HW40 Blue screen and then shut down
The tv shutting off can be explained by some kind of protection circuitry turning the set off.. This can be due to a variety of reasons most common reason being overheating.
Posted on Nov 25, 2008
  • 121 Answers
SOURCE: bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Posted on Feb 25, 2009
cactus bob
  • 267 Answers
SOURCE: Magenta TV color goes magenta
CALL HIM BACK . sometimes when we troubleshoot a problem another one pops up ,when troubleshooting we move boards and unplug connectors . there can be dirty connections that pop up when where done and even a broken solder joint as well . he should fix it for free . i know we do and it does happen to us once in a while . good luck
Posted on Mar 09, 2009
Sony KDL-50EX645 purple vertical line between the panel
In most of the case, the display panel (screen) is bad. Please contact SONY customer service ASAP.
Apr 17, 2014 | Sony KDL-50EX645 50" LED TV 1920x1080, 240...
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Nov 20, 2013 | Televison & Video
My sony flat screen works but when I turned it on the colors are blue and purple. Picture not clear but sound is ok. Colors are off.
Press "Input Select" on the remote control and select "TV Mode."
Press "Menu."
Press "Enter" to select "Picture."Use the arrow buttons to select
"Picture Setting."
Press "Enter."Use the arrow buttons to select "Color."
Press "Enter."
Use the left and right arrow buttons to adjust the color settings. When you are pleased with the color setting, press the "Exit" button on your remote to exit the menu screen.
Hoped this helped
Mar 18, 2011 | Televison & Video
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Intermitant color bursts of red, green, purple
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
May 31, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Disk doesn't spin up
check the disk, clean it, put back in. disk my be bad.
Nov 24, 2007 | Sony PlayStation 2 (PS2) Console
Sony Trinitron 32 tv
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Triple picture and purple bubble on big screen
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Sep 25, 2007 | Sony KP-48S70 48" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
