Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Power led is on but water does not start to go in even after the machine is turned on. Now the door is locked with clothes inside. How do I open the door ?
  • pw3638 Nov 17, 2008
    THANK YOU JIMSTER. I TRIED YOUR METHODS BUT COULD NOT SOLVE THE PROBLEM. SO I FORCED THE DOOR OPEN BY INSERTING A SCREWDRIVER BEHIND THE HANDLE OF THE DOOR. DOOR IS OPENED NOW BUT THE WASHER IS NOT FUNCTIONING, WATER STILL WONT START TO GO INTO THE MACHINE .
  • 240 Answers
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Posted on Nov 16, 2008
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Whirlpool AWM 8143 - Starts a cycle and then starts flashing open door light and won't go further. Door is shut properly. Tried turning it off at the power and back on to no avail.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Jan 18, 2011 | Whirlpool AWM8143 Front Load Washer
Whirlpool model AWM 6101 door wont open after washing has finished
the door can take anything up to 2 and a half minutes to open anyway but if it takes any longer than this, or will simply not open at all then you will need to get a replacement door interlock switch
May 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Problem with whirlpool AWM 1000
It's not indicated to put much detergent ( washing solution), because it will stop water acces, causing acumulation of water, then the LED will indicate Hydro-Secutity. The solution is open the washing mashine you'll see that you need to evacuate water then to clean manualy the indicator ( Hydro-Security). That's all, I hope that i my information was helpful for your problem.
Jan 18, 2009 | Washing Machines
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 8103/S Problem
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Oct 07, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
320 people viewed this question
Dan Webster
Dan Webster
Sal De
