Question about Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC
Windows Installer Box keeps popping up!
How do i stop the windows installer box from suddently popping up virtually every time i seem to click on anything?
    Genius:
  • 1,913 Answers
First find what u clik it may be windows word or officw 2003 problem.
remove ms office 20003 or any version.then install again.
Posted on Nov 16, 2008
How do i stop my windows intaller trying to install symantec antivirus msi file
Step 1:
Stop Windows Installer From Popping Up b> The older a computer gets, the more junk it accumulates. A great number of computers out there don't start up without a thousand things popping up demanding your attention. Windows Installer is one of the more notorious pop-up offenders for Microsoft users. Stopping these pop-ups can prove challenging, however, there is a way.
On your computer's desktop, click on the "Start" tab, typically located on the bottom left of the screen (in Vista it may be the Windows symbol rather than the word "Start"). Now locate and click the program titled "Run." Vista users can locate this program by typing "run" in the search box at the bottom of the "Start" menu. Once "Run" is open, type "MSCONFIG" into the empty box and click "OK." This will open the System Configuration Utility. With the System Configuration Utility open, select the tab labeled "Services." Scroll down the list of services (it may be beneficial to click the "service" column to sort the services alphabetically) until you find the "Windows Installer" program. Now click the check box beside the Windows Installer name and click the "Disable" button at the bottom of the System Configuration. Congratulations, you have stopped "Windows Installer" from popping up!
Feb 06, 2013 | Acer TravelMate 4150LCi Notebook
I'm trying to install Gmail Talk and keep getting Error 1622
You may follow the steps given below and check if that helps to get rid of the error message while installation of application.
a) Click on Start
b) In the start Search box type Services
c) Right Click on"services" on top of the pop up and select Run as Administrator
d) Stop "Windows Installer" service.
e) Then, delete the temp folders; there may be a file in there interfering with the setup routine of the installer. Get both:
C:\Windows\temp
C:\Documents and Settings\<username>\local settings\temp
f) Finally, set your "Windows Installer" service's startup type to "Manual".
g) Reboot your system and have another test.
Hope this information is helpful.
Aug 16, 2012 | Google Talk
I purchased Hebrew Tutor and cannot install it on my Windows7, 64-bit computer. Please help.
Unfortunately, the Hebrew Tutor from QuickVerse was written for older Windows OS versions. It supports: Windows 95, 98, ME, 2000, XP Home, XP Pro, or NT 4.0. The changes in the Windows OS over time has made the installer totally different and the program isn't signed for a 64-bit OS. http://www.quickverse.com/shopfiles/product_details.asp?ID=41011 has the support details.
There are two possible ways to work around the issue. The first is to try to install the program (and then run it) in the compatibility mode. This may work but often doesn't. Right click on the installer (from the CD's directory) and choose Properties. Then go to the Compatibility tab and chose Run this program as compatible with XP. Save and close the properties box. Then right click again on the installer and choose Run as Administrator. If it installs, repeat the compatibility process on the program itself.
The solution most likely to work is to use a computer with the compatible OS versions. This could be a physical second computer, a dual-boot machine or a virtual computer. If you have Windows 7 Pro or Ultimate, you can run the virtual computer with XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. For other setups, you will need a licensed version of the older Windows OS. Virtualization packages include Virtual PC, Parallels and VMWare. Then install the Hebrew tutor as you normally would to an XP computer. (Note: virtual computers do not share hardware with the real computer. You can only install a printer to one machine at a time. You can share files by saving them to external media (optical RW disc or flash drive for example).)
I hope this helps.
Feb 21, 2011 | Computers & Internet
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
Windows Installer - Preparing To Install message keeps popping up
Try using the 'Windows Installer CleanUp Utility'. This utility helps resolve installation problems for programs that use Microsoft Windows Installer. If you use this utility, you may have to reinstall other programs. Caution is advised.
Use the following link: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
You must be logged on to Windows with a user account that is a computer administrator to run Windows Installer CleanUp Utility.
When you use Windows Installer CleanUp Utility, you can perform the following functions:
  • Select one or more programs that were installed by Windows Installer from the Windows Installer CleanUp dialog box.
    To do this, select the programs that you want in the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only Windows Installer configuration information that is related to those programs.
  • Remove all Windows Installer information associated with the selected programs. This includes the entries for the programs in the Add Or Remove Programs item in Control Panel. Be aware that only the Installer information for that particular program is removed, not the files.
If you use this utility to remove Windows Installer configuration information for your program and you plan to reinstall the program, you should reinstall the program in the same folder where you originally installed it. This prevents duplication of files on your hard disk or disks.
Apr 08, 2009 | Computers & Internet
Windows Installer pops up everytime I open Access, Excel ..etc.
your applications didn't full instalations..try to reinstal n upgrade your software..
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
Windows pop up problem
Hey,
try to use Windows Installer CleanUp Utility to fix the problem:
http://tinyurl.com/45x45
or try this solution from Microsoft:
  1. Click Start and then click Run.
  2. In the Open box, type Regedit and then click OK.
  3. Locate and select the following key: HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Common
  4. Select the UserData DWORD value for the above key.
  5. On the Edit menu, click Rename.
  6. Rename the UserData DWORD value to UserDataOld.
  7. Find the following key: HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Common
  8. Find the following value: OSAShortcut. If it does not exist, create it. On the Edit menu, click New and then click Dword. Name the value OSAShortcut, and then set the value to 1.
  9. On the Registry menu, click Exit.
  10. Start any Office program.NOTE: The same Windows Installer dialog boxes appear one more time.
  11. When you are prompted, type your name and initials in the User Name dialog box, and then click OK.
good luck :)
Jan 03, 2009 | Microsoft Windows XP Professional
Installing Linux
you can use virtual drive to install linux within windows os. you can download virtual drive for free look for virtual box version.
Dec 16, 2008 | Microsoft Windows XP Professional
Windows installer problem
WHAT WAS THE MESSAGE ON THE POPPING BOX?
Oct 31, 2008 | Computers & Internet
Open Questions:
Starwars Battlefront 2: Wont Install I just finished downloading Starwars Battlefront 2 from: http://www.warez-bb.org/viewtopic.php?t=5343241&highlight= It says I need these requirements to play: (The words in the brackets are what I have) Operating system: Windows 2000/XP (Windows XP) Processor: Pentium 4 1.5 GHz (Genuine Intel(R) CPU 2140 @ 1.60GHz [2 CPUs]) Memory: 256 MB (1024MB RAM) Video: 64 MB (512MB) Sound card: compatible with DirectX 9.0c (DirectX 9.0c ) Available at Railway: 5.5 GB <- What does this mean? CD-ROM speed: 8x <- How do I check? Do I meet the requirements? I extracted it; opened up the file and inside there was 4 files: Disk1(712,674kb) Disk1(1kb) Disk2(367,454kb) Disk2(1kb) They are all MDF files. I open either of the Disk2 files and it has junk like DirectX, Docs, some setup-2.bin file? I open either of the Disk1 files and "Starwars Battlefront 2 Autorun" opens, it has four options, they're all in a very weird language, and only 2 of them are clickable.. The second one gives me this: ýòàïû çàïóñêà èãðû 1 - óñòàíîâèòå èãðó. 2 - ïåðåçàãðóçèòå êîìïüþòåð. 3 - çàïóñòèòå èãðó, ïðè ýòîì ïîÿâèòñÿ äèàëîãîâîå îêíî. 4 - íàæìèòå êíîïêó KPAK è çàêðîéòå ýòî îêíî, íàæàâ êðåñòèê â ïðàâîì âåðõíåì óãëó îêíà. 5 - èãðà çàïóñòèòüñÿ àâòîìàòè÷åñêè. I think it's a readme.. The first option opens an installer.. it's in that language.. I run threw the installer and it begins to installer, but halfway threw I get an popup.. I think it's asking me where I want to save something.. It has a bar where i'm suppose to put a path, the default is G:\, when I click ok is has ???? "setup-2.bin" ???? "G:\" ????. The ?'s meaning the random language.. I click browse and click on other options but it has the same result for everything.. Please help somebody!
May 06, 2010 | Wise Solutions Wise For Windows Installer...
Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC Logo
345 people viewed this question
Top Wise Solutions Computers & Internet Experts
David Payne
David Payne
Are you a Wise Solutions Computer and Internet Expert? Answer questions, earn points and help others
