Question about Grilling
Why won't my Weber grill ignite after installing a
    Problem Solver:
  • 6 Answers
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Posted on Apr 24, 2012
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
Bought a brand weber sprit grill from home depot. Used 4 times. Won't go above 350
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ';';
Aug 11, 2011 | Weber Genesis Silver B Grill
I'm trying to start grill, it has a full propane tank , it ignites then it turns off
You might have a bad propane tank. If the tank is new take it back and tell them you think the valve is bad. They should exchange it free of charge. Sometimes the valves on the tanks go bad, then they just don't get very much gas and can easily shut off.
Jun 06, 2011 | Weber Genesis E-310 Gas Grill
I love,love,love my baby webber. I bought it when they first came out. I can only use the tall, blue propane bottle. I seen some where that they were using the short, wide, green one. My wire guide...
The easiest solution to this problem is to remove the screw securing the wire tank holder in place, and then just bend the holder a little bit wider so that it will fit the slightly larger 16 oz green tanks found in the camping section of most stores.
You can even buy buy a hose connector adapter for it so that you can hook it up to a large home barbeque type propane tank if you want. See the following consumer reviews of that unit for more details and ideas:
http://www.amazon.com/Weber-Baby-100-Portable-Grill/dp/B0000E6GHI
Thank you and good luck.
May 22, 2011 | Weber Baby Q Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Aug 20, 2010 | Weber Q300 Grill
Genesis GE310 Gas Grill: I just installed a full propane tank on my Weber, ...
Maybe just clearing air out of the line, other than a minute would not be normal.
May 18, 2010 | Weber Genesis GE310 Gas Grill
Grilling Logo
670 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
