Question about Starbucks Barista Burr Grinder
Replace motor - barista burr grinder EL 60
The motor has stopped working and I cannot get at it. How do I check it and how do I replace it?
  • Anonymous Dec 29, 2008
    Grinder does not operate. Do not find any access to motor to solve .
  • Anonymous Apr 28, 2009
    I also cannot get the grinder to work. I can hear the timer but no motor and don't have any idea on how to open it?
4 Suggested Answers
SOURCE: does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
Posted on Jul 11, 2008
  • 1089 Answers
SOURCE: Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
SOURCE: Motor revs but grinder does not engage.
I am what you would call an expert when it comes to Baratza repairs.
The problem you are describing is not an unusual one. It sounds like the main drive gear has been stripped due to something foreign (likely a stone) sneaking into your grinder with the beans. It would have jammed the burrs, and because of the powerful torque from the motor, the drive gear has been stripped so it will no longer (or rarely) engage the burrs.
To solve this problem you will need to contact COAG Ltd (if you live in Canada) or Baratza if you are from the US. If you machine is still under warranty (less than a year old) this repair will be free of charge and you shouldn't be parted from your grinder for long.
I hope this helps anyone who stumbles upon this and finds themselves with the same problem.
Kind Regards
Emily
COAG Ltd.
877 477 3849
Posted on Jul 21, 2009
SOURCE: My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Posted on Sep 26, 2010
I have Barista grinder. I've had grinder for about 3-4 years and it stop moving. I unplugged cord, tried to turn the feeder and plugged in still not moving except timer is clicking. I wonder why it...
Hi It could be the timer switch but if you hear the timer move(whirring) it is probably OK. There is a thermal fuse on the motor that will go out and you just have to replace the thermal fuse. Its under the wrap on the side of the motor. Which grinder do you have?
Jul 07, 2011 | Starbucks Barista Burr Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
Electrical cable burn and grinder stopped working Should I replace thermal fuse.
If the wireing burned, you should replace it as well as the diode.
Feb 15, 2011 | Starbucks Barista Burr Grinder
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
Motor stopped working
Hi
There is a thermal fuse on the side of the motor to prevent the motor from burning up. You can replace the fuse (it is a 103c thermal fuse, crimp it on ) and you should be in for more grinding.
It could also be you timer switch, or bean hopper switch, or a broken tab on your adjustment collar.
Jul 25, 2009 | Starbucks Barista Burr Grinder
Jun 07, 2009 | Starbucks Barista Burr Grinder
Non-working Starbuck's Barista burr grinder.
Hi
Remove bean hopper
The thermal fuse is to protect the motor its a 104C
May 12, 2009 | Starbucks Barista Burr Grinder
Hi
Remove bean hopper
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Does not grind
May 14, 2008 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
419 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
