Question about Braun FlavorSelect KF 180 Coffee Maker
Braun Flavor Select will not brew coffee.
The machine turns on but brew cycle will not start. Also, burner donly becomes slightly warm. When it died, it had been set for 12-cups but stopped after about only 4. The machine is only about 2 years old.
  • 1 more comment
  • corvette2 Nov 17, 2008
    Coffee maker worked great for a couple of years and one day turns on gets a little warm but won't brew coffee.
  • Anonymous Jan 30, 2009
    hello
    I have a Braun FlavorSelect purchased in 1996. It has been used heavily since then! Within the last year or so, it seems to be leaking and recently, it has stopped brewing. I know it's old, but it has been a great coffeemaker up to now and I can't afford to buy another ...
    From what I can see from your site, it appears I have two problems-
    1. corrosion and 2. calcification.
    I'm going to go to the hardware store today and try to get the items you mentioned. It's worth a try to fix my poor old unit.
    Thank you very much for the practical solutions you offer.
  • Anonymous Mar 30, 2009
    On my Braun FlavorSelect KF 180 coffee maker, the red "CAL" light on the left side is on and the coffeemaker will not start.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Posted on Jan 26, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
The brew water is not very hot, flavor is weak and the brewed cup is luke-warm
Thermal sensor is bad and needs factory attention. Return for service.
Feb 02, 2012 | Keurig Elite B40 Coffee Maker
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Light stays on as heating does not want to brew
1. the sensor circuit is defective.
2. the coffee maker needs to be serviced.
there is a circuit that shuts the unit off when brew is complete but the current of voltage sent to signal end of brewing cycle is not enabled therefore the light stay on.
Mar 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
Bad taste
There might be some residue in the machine, you can try using some ScaleKleen which is activated citric acid, use a very small amount diluted in water(about 1/4 teaspoon). Run brew cycle with solution, after cycle complete, rinse reservoir, and run about 4 cycles with fresh water. This will clean out your machine.
Apr 05, 2009 | KitchenAid KCM511OB 10-Cup Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Black and Decker Coffee Maker DE790B
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Sep 05, 2008 | Black & Decker (050876530606)
Braun FlavorSelect KF 180 Coffee Maker Logo
912 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
