Question about Canon i80 InkJet Printer
Cannot find information on waste ink absorber for Canon i80
Every time I print on my Canon i80, I get message "The waste ink absorber is almost full". So far, it will still let me print, but... I have searched the user guide and cannot find any information about where the absorber is, what it is, what I do when it's almost full, etc. Help, please.
  • 421 Answers
The waste ink absorber collects any spilt in from the head and stops it leaking out or sitting in the bottom of the printer casing. The printer is telling you that the one in yours in nearly full. You know have two options:
1. Replace the waste ink absorbers and reset the counter (will require taking the printer apart)
2. Reset the counter only (you run the risk of ink leaking out)
The waste ink absorber for the I80 can be got quite cheaply if you google about.
You can reset the counter by:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press
the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in either orange or green, starting with orange.) During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times.
Hope that helps
Posted on Nov 16, 2008
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
When i try to print i get a message "used ink tank is full" canon i350
This applies to Canon printers but since you did not specify the printer name and model here is the information I have courtesy of Canon's Support Website.
Don
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 01, 2009 | Canon Office Equipment & Supplies
Waste Ink absorber
selectable.)
button.)
green.
Jul 21, 2009 | Canon i80 InkJet Printer
Waste ink absorber is full contact service center message
waste absorber full reset sequence for the I80.
1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time.
2)Release the Resume/Cancel button. (continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons.
4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green.
5) Turn the printer off and then back on. You should be good to go. Unfortunately when the tank gets completely full it will stop printing. The cost of repair however is more than the cost of replacement.
Jun 03, 2009 | Canon i80 InkJet Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Ink waste absorber is full
http://www.cyber-ink.com/member-canon.html
Jan 30, 2009 | Canon Office Equipment & Supplies
Waste ink absorber full
Try the following procedure: 1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time. 2)Release the Resume/Cancel button. (continue to hold down the power button) 3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons. 4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green. Power it off and back on and you should be good to go! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
399 people viewed this question
old marine
old marine
