Question about EdgeStar AP10000HW Portable Air Conditioner
Edgestar AP10000 Portable AC Won't heat or cool.
I have had this air conditioning unit for nearly half a year now. When I first got it at the beginning of summer, it wouldn't ever put out cool air. I decided to bring it back out for fall/winter, but it turns out that the thing won't heat, either. Could it be due to the exhaust hose? Due to the placement of a desk, the hose is bent at an odd angle to reach the window. It's still blowing air out of the hose, I know it has to be because it blew a bunch of leaves off of my window sill when I first turned it on. Anyone have any ideas?
  • 8 Answers
SOURCE: Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Posted on Mar 13, 2009
SOURCE: edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Posted on Dec 12, 2007
  • 4 Answers
SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Posted on Dec 29, 2007
micromaster
  • 3614 Answers
SOURCE: EdgeStar 400S portable AC
how old now the unit..? is it new?
Posted on Jul 24, 2008
  • 51 Answers
SOURCE: Hello.. I am looking for the bottom squirrel Cage
If you take off the back filter panel, you can look down into the innerds of the unit and you will see the squirrel cage.
Posted on Jul 10, 2010
My Edgestar AP12000HS no longer dehumidifies
Check to see if it is leaking water out from the bottom , also make sure that condensate pan is set properly
Dec 19, 2017 | EdgeStar Portable Air Conditioner ...
How far from floor should exhaust hose hole be made edgestar 12000
makes no difference, as long as the ducting is not kinked.
keep in mind heat rises
so obviously if you could dump the heat elsewhere, away from the area you are cooling, then it would not creep back up through the floor. If your flooring is well insulated it will not matter.
Oct 10, 2009 | EdgeStar Portable Air Conditioner Heater
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Water leaking
You have to open it and clean out the water passages.
Jul 23, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar Portable AC/Heater
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Dec 02, 2007 | Heating & Cooling
Heating
http://www.edgestar.com/ownmanuals.htm
Here is the URL for the Edgestar owner manuals. You can select your unit on the page. You'll need Adobe Reader to view the manual.
Nov 28, 2007 | EdgeStar Portable Air Conditioner Heater
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar AP10000HW Portable Air Conditioner Logo
104 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
