Question about Goldstar MV-1501 Microwave Oven
No heat Everything else works light turntable clock keypad.No heating of food at all
  • Gary Labute Nov 29, 2006
    I messed up a little in my previous, It was an MV1526W. It also made aloud buzzing noise too. Diode?
  • aluvera Sep 15, 2008
    daewoo kor- 63fbsl 1000/700watt. 2450mhz. problem.. no heating of food.. found inline fuse between capacitor and transformer at magnatron had overload symtoms in glass fuse [ fuse is a slow blow or anti surge 5kv.550mA 41mm x5 mm ] 14 months old.
  • Goldstar Master
  • 9,156 Answers
The most likely causes are defective a door switch (or switch mount), a bad connection in the high voltage section, or on the controller. I would direct you to my safety text file and door switch text file for critical safety info anf info on testing & replacing door switches. You can find it via searching on Yahoo.com (not Google) for: microwave safety.txt After you check that out, please repost so we can hel you further.
Posted on Nov 28, 2006
SOURCE:
My microwave is not heating food although everything else seems to be working. What do you think is wrong? Would this be a costly repair?
Sounds like the magnetron tube has burned out so you don't get power. It's the heart of the microwave. Time to shop for another, not worth repairing.
Oct 02, 2018 | Microwave Ovens
Food is not heating, can u help me?
If the only problem is that the food does not heat up, but the rest of the oven works, like the light, turntable, display and keypad, then the problem is with the magnetron circuit. It the circuit that generates the microwaves that heat the food. It can be expensive to fix since the replacement magnetron can cost as much as a new oven, so it rarely worth fixing. The symptom of a shorted magnetron is a loud buzzing sound when you try to run the oven.
Jun 03, 2011 | Sharp Microwave Ovens
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Unit is 10 years old. Everything is working (keypad, lights, turntable) but unit is not heating food.
heatman101
Oct 06, 2010 | Maytag MMV5000 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Not heating food
While it's possible it could be a door switch or mount, it's most likely a bad magnetron or a bad connection at the magnetron or on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Samsung models here: http://www.samsungparts.com/search/search.asp
Apr 25, 2007 | Samsung MW1030WA Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
174 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Kevin
Kevin
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
