Question about Carrier Heating & Cooling
The power has been out several times and I believe the heat settings are not working. How can I reset the heat? I have misplaced the manual.The temp in the house right now is 60 and it is 33 degrees outside. Can some help please?
    Problem Solver:
  • 8 Answers
What type thermostat do you have and how old are your components
Posted on Nov 16, 2008
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
I have a Kenmore Ultra Wash Dishwasher model# 15867990. The Sani Rinse light stays on and when you press another button the lock on button comes on and then the dishwasher will not start. I have tried...
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 17, 2011 | Kenmore Dishwashers
My Whirlpool is heating up intermiitingly. Believing the problem to be the heating element i replaced this but the problem is continuing' This led me to believe the problem could be the controls. Now...
thermistate solide state usually mounted to the frame of the oven this heating and controlling temp, if it goes faulty you can get a replacement from a good local electrical store. The numbers on the case will be required as there are several types, and temps ie 65 degree, or above, this component prevent overheating do not bypass.
May 17, 2011 | Whirlpool Ovens
Normal light is flahing unit will not go on sometimes time remaining indicator will flash started awhile back by not being able to change any settings but unit would work now nothing have tried...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Feb 04, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Model ace184xro quits running on heat about 20 min after turned on. Will not reset.. any solutions
Check your heating sensor. May be defective or misplaced. And also check your temp setting +8 degree from your room temp.
Dec 14, 2010 | Whirlpool ACE244XS Air Conditioner
We just bought a qca topaz hot tub from a person and we can't seem to get the jets to shut off. Any ideas?
reset the filter timer on the unit probably set at max since being powered up [replugged in ] 6hrs out of 12hrs every 12 hrs if u have manual will explain how to set temp and filter run time if no manual can notify company and they can advise --i believe on yours that if u hold down the light button for a few seconds it will flash a number and u can use up and down adjustment arrows to reset time usually set at 1
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Water not heating up enough, misplaced a manual.
Here is a place where you can get manuals
http://www.cerinicoffee.com/Saeco_User_manuals_free.aspere
I have had this problem before: Could be two things either the boiler or the sensors that measure the temperature of the boiler. Normally the red flashing light that you get on startup will never go away if the boiler doesn't get to temp. If your light goes to constant red, it means that it thinks the boiler is at temp ( but it isnt). That points a bit to the temp sensor.
There are two sensors, one that regulates the temp and one that is an emergency cut off device incase the boiler gets too hot. Both must be working. If you download the manuals, they will show the position of these (if its the more detailed manuals with parts.
Taking these machines apart and putting them back together is a bear of a task, I have done it several times. Might be worth taking it in as you have to pull the whole assembly out of the container to get to the boiler.
Hope that helps.
Dec 24, 2008 | Saeco Vienna SuperAutomatica Coffee...
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Oven not heating after self-cleaning cycle.
That did it for me too. You saved me a $200 service call!
Nov 05, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
