Question about RCA F25432 25" TV
RCA Model number F25432
The picture does not work but I do have sounds also I have control with the menu just no picture at all. I will try the other solution. thanks,
The horizontal output transistor my be shorted out, or the flyback transformer my be open? Have you unsoldered and tested? If you are not a technician, or have no experience I would not suggest to work on the tv yourself. good luck, Mike
Posted on Nov 29, 2006
F25432 need to find out where to get a remote RCA
By precious solution, I've pointed out the setup codes to RCA TV with RCA RCR311W model remote control. I repeats. 1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205. For more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Televison & Video
I have a gold gemstar/rca 36inch tv and I can't
to enter the codes u must use yhe orig. remote
May 22, 2010 | RCA F25432 25" TV
Tv turns on but no picture but has sound and menu
55" rca projection tv turns on has sound but no picture
Feb 11, 2010 | RCA Televison & Video
Model number F25432TX1
From your cable box you can use the audio outputs to port it through to your home theater system.
Apr 20, 2008 | RCA F25432 25" TV
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
NEED ASSISTANCE
Here is the infomation you need...
Feb 16, 2008 | RCA F25432 25" TV
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Sep 29, 2007 | RCA F25432 25" TV
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
RCA Mdoel number F25432
Is that an L4401? Your missing a number if thats an RCA part number. You did not state if the sound was also gone out. This coil does not go bad, but needs to be unsoldered, then the leads need to be scraped off and then reinstalled and resoldered. This will make the set go on and off all the time. Not just turn off the picture. This coil is located on the printed circuit board, and connects the secondary of the horizontal driver transformer secondary to the base of the horizontal output transistor. Also if the set trys to start up three times and stops, the flyback is bad and is no longer available. if you have no tV repair experience, play it safe and seek out a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Nov 26, 2006 | RCA F25432 25" TV
RCA F25432 25" TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
