Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv shuts off after awhile
2003 tv rca model# d52w20yx1 shuts off after it warms up sometimes 15 min. sometimes 2 hrs. is it worth repairing an what part could it be thank you pat
  • matt_cruz Nov 16, 2008
    I have the same tv and mine turns off by itself sometimes but now it lights up the power switch then it goes off then on then off, but never really turning it on,
  • daija1209 Nov 17, 2008
    I'm experiencing the same problem, I gota multimeter so now I'm going to test all the diodes and hopefully find the problem. The way to test is by touching the diodes on side and and then reversing the procedure. There should only be one reading, if you et two readings there's the bad diode. The current should only flow in one direction. Go to your locl radio shack and replace the bad one.
I HAVE A 36' RCA , WHEN I TURN IT ON ITS SHOWS A GREAT PIC. AFTER ABOUT 30 MIN TO 2 HRS IT WILL SHUT DOWN ITS MAKES A POP SOUND, AFTER ABOUT 30 MIN OR MORE I CAN TURN IT BACK ON, BUT NO SOUND I HAVE TO TURNS SPEAKERS BACK ON FOR SOUND
Posted on Dec 30, 2008
  • RCA Master
  • 5,138 Answers
Check 3 capacitors cp150- 2200uf 16v if it is puffed up on top it is bad so replace 2 other caps cp120&cp114 220uf 35v they will be green with gold writing on them and are located on Deflection board,it has your Flyback transfomer on it.Resolder all pinns on FBT.
Posted on Dec 23, 2008
  • 88 Answers
DEAR fleming_pj
OPEN YOUR TV AND TRY TO RESOLDER ANY LOOSE CONTACT.
OR CHECK POWER SUPPLY UNIT .IT COULD FIX YOUR PROBLEM.
OK
Posted on Nov 16, 2008
  • CHECK THE CONDITIONOF CRT.
    AND GET ESTIMATE OF SPARE COST BY YOUR SPARE DEALER AND YOU DESIRED TO REPAIR YOUR TV Or. REPLACE.
    OK THANKS.
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
Starting problems after warms
CHECK YOUR FUEL PUMP PRESURE
Mar 17, 2009 | 2003 Ford Expedition
I have an RCA SDTV Model: 24V414T The TV shuts off by itself after 1-2 min. and turns on by itself in the next 1-2 min and the process goes on. Can anybody help with this problem. Thanks
i have an rca tv shuts off by itself lite only the standby power after 2-5 minutes you can turned it on and will off automiticaly pls. help me with my tv model 24v414t.
Sep 21, 2008 | Televison & Video
RCA 52 inch tv will not come on and has no sound
you can get your TVs deflection board remanufactured at the following link for alot less than that shop is saying and they guarantee the board for 6 full months.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv powers off after 15 mins to 2 hours
what is the model # and brand
May 02, 2008 | Televison & Video
Sound problem on TV monitor L 2010
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
Feb 07, 2018 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
RCA 32V550T 32" TV Possessed
I am having the same problem with my RCA 32V550T. This has been the worst purchase I have ever made - it was an expensive TV at the time that I got it and it only worked for a few months. It may or may not come on. It may or may not have sound. It rarely works but If per chance it does come on it will work maybe from 15 mins to 2 hrs. depending on it's mood - yes I think it is possessed. It turns on and off at will. I keep it unplugged most of the time because I worry it may be a fire hazard. I have had it repaired but the problem persists. It's a useless but expensive heap of junk taking up space in my living room. I had a great RCA VCR that I bought many years ago but contemporary RCA products are not the quality they used to be - be smart and stay away from them.
Dec 15, 2007 | RCA 32V550T 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
199 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
