Question about Acer Computers & Internet
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a walkthrough of how to do it please. Darryl Tunnicliffe
  • 749 Answers
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Posted on Nov 16, 2008
Attempted to install service pack 3 but received error message: C:\windows\system32\drivers\acpi\sys.
Hi Michelle,
This problem happens if you run "Alcohol 120%" and "DAEMON Tools" applications. If you don't have these apps installed follow the below step to fix this issue.
  1. Go google "Unlocker Assistance" and download the software (or the link is provided below), it's free and very useful program. This program can unlock or kill or delete any files that's being used, no matter what situation the file is on, it can unlock the file or kill the process which is using it. (The icon looks like a star magic wand, that's the right program)
    Download the software below if you have trouble finding it. http://www.techspot.com/downloads/1029-unlocker.html
  2. After you install the program, then go in your My Computer, and right click on the C:\ and click on Search. Then find the keyword "atapi.sys" that the error message mentioned. You will see an icon that looks like a white sheet of paper, right click on that and choose "Unlocker" on the menu. I don't know if this would show up by default, but it should. After that a window should pop up showing you which program is currently using the file, I think it was "System". Now you need to click either on the "Unlock" or "Unlock All".
  3. After that, the "atapi.sys" file should be unlocked. Now, go back to the error message and you should see "Retry" or something like that, then just click on that. Viola, the process will continue on.
Feb 07, 2012 | Microsoft Windows XP
When I format the hdd and installing win xp sp2 Blue screen keeping reporting tha the bios is not fully acpi compatible and I'm unable since to get it done
im sorry there is no one answer to this problem a couple of possible solutions are to 1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
you could have a bad stick or sticks of ram
or you need to flash/update you bios
or you need to clear the cmos [removal of battery or a jumper switch depending on your mobo]
once again im sorry to not have a clear one size fits all solution to this problem i hope this helps you and please vote for me
Dec 05, 2010 | Computers & Internet
BSOD keeps on flashing during installation of Win XP
I think the problem is with your RAM installed, try to swap other memory on your computer or try your RAM to other PC to determine if its working.
Jul 11, 2010 | Asrock P4VM8 Motherboard
Standby function doesn't work
The stand by button is greyed out when A) your computer is too old to support the
Advanced Control Power Interface (ACPI) or B) ACPI is not configured properly.
Start->Control Panel->System->Hardware tab->Device Manager button. Do any of the
items have a red 'X' or a yellow '!' beside them?
Mar 01, 2010 | Acer TravelMate 2500 Notebook
The BIOS isn't ACPI compatable xp BSOD's during Startup toshiba m45-s265
If you have problems with the ACPI, just go to the BIOS menu and disable it.
Don;t forget to rate this answer if it helps
Dec 27, 2009 | Toshiba Satellite M45-S265 Notebook
Acer travelmate 2410 boots then gets bsod. when trying to boot in safe mode get bsod. have just removed 15 viruses and worms from this thing. with the viruses it would boot then freeze. system restore...
get a copy of the windows set up disc, I allways have one to hand & re-install from scratch, It's easy just get a disc copy from an IT shop boot it up with the cd in & follow the instructions, the key code will be needed, thats on the barcode windows sticker underneath the laptop.
best of luck, I've had to do it a few time's!
Sep 21, 2009 | Computers & Internet
How do i update bios on an acer travelmate 2500 - downloaded bios update onto another pc as i can't install xp due to acpi etc blue screen?
http://support.acer-euro.com/drivers/notebook/tm_2000.html
Scroll to the bottom and you will find the download for the update.
P.S. DON'T FORGET TO VOTE!
Apr 16, 2009 | Acer TravelMate 2500 Notebook
My Acer travelmate 2300 usb ports aren`t working
What has changed most recently? did they work before? May be disabled in bios, need more info.
Jan 24, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 2501LMI - bios update
If you have access to the original disks that came with the machine I would suggest trying to use those.
Is the harddrive SATA?
Try installing XP on the hard drive through another Laptop or a USB converter. Then place the drive back in the computer to start windows.
Mar 14, 2008 | Acer TravelMate 2501LMi Notebook
Blue screen in A8N32 SLI Deluxe Motherboard which worked excellently-ACPI
I had this issue myself. It took a very long day of searching... but all I ended up having to do was disabling the parallel port in BIOS. (I even went so far as to update BIOS, and the bugger just wouldn't load past the Windows loading screen unless I turned off that stupid parallel port.
I know this solution is late, but maybe it could help.
Mar 10, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Computers & Internet Logo
399 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
