Question about CyberLink PowerProducer 2 for PC
Cyberlinkpower poducer fails to add files for burning
What can i do
  • 31 Answers
Hi there if you have the software of the program tries to reinstall it again it maybe corrupted in the computer system. First uninstall the software then restart your system please be patient every time you install or reinstall please reboot your computer system.. Then install it then restart again... If you have still issues with this you can contact me again. Thanks have a nice day Please rate. Thanks again.
Posted on Nov 16, 2008
I can't unlock my tablet
Best info found;
"The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
http://www.craigelectronics.com/firm...irmware4.0.rar
(install instructions: http://www.craigelectronics.com/firm...guide_741e.doc)
HOWEVER! Some CMP741 units will end up stuck on the green Android screen with this version!
If that happens, Craig has supplied a cleaner firmware in case that the first one fails,
http://www.craigelectronics.com/firm....0_cleaner.rar
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue.
The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again."
Aug 17, 2013 | Craig CMP741d Tablet
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I have a Dell Dimension 4600. When I burn an AVI file and play it back, there is some missing audio and jumping video that occurs. I have burned DVD videos with no problems. What could be wrong here? Thank...
1st convert AVI files to MPEG2, use a good converter....
use WINAVI 9...
use a codec called FFDSHOW....
use Nero (Nero Vision) to burn DVD...it will take some time...to burn...
i bet your will never fail .
or
just
add the AVI file in Nero(Vision...make movie option/ Export option / Configure option...) and let it convert to MPEG2 first....
then use the Make DVD option in Nero Vision and then make your menu etc and Burn
Jan 21, 2011 | Dell Computers & Internet
WHEN I BURN A MOVIE IT WON'T SHOW UP ON DVD DISC
Sounds like it may have burned the movie file as a data DVD.
In other words, the file gets burned to the DVD just like a Word doc or spreadsheet would, rather than encoded as a movie.
You need to check what format you downloaded it in - it may need conversion before burning as a movie DVD.
You can run a quick web search for *** (your current file format - mpg, divx, etc.) to DVD and find a free utility for conversion.
Then your burning software should be able to burn it as a movie DVD, ready for your player.
Aug 01, 2009 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Can'y burn avi files to dvd
You should try to burn the .avi files through nero burner.
Nero 7 or 8 will do, but you'll be able to burn only 2-3 .avi files through nero.
Apr 12, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
HOW TO BURN MKV FILES TO DISC USING NERO
Hi there.
You need a MKV to DVD converter, get solid MKV -DVD converter here >>>>>>
http://download.cnet.com/Solid-Mkv-to-DVD-Converter-and-Burner/3000-2646_4-10869587.html
Good luck and thanks for using FixYa!!
Apr 06, 2009 | Computers & Internet
PowerProducer3 'failed to add video file'
I solved this problem by using a different program as I could not resolve the error with the cyberlink software.
Sep 09, 2008 | CyberLink PowerProducer 2 for PC
I need to burn a movie from window movie maker to a dvd but i can only save to a cd can you please help me
hi im wesley. what you can try is insert a dvd using nero if possible then select burn dvd video files then go to add files and search for the files on your pc add them all and say burn it should work but make sure you save the file from movie maker to a folder otherwise you wont find it.
Jul 21, 2008 | Computers & Internet
DVD Builder
You have to use the burning software like nero to create a DVD from a .wmv file.Start your nero software and select which file you want to burn .select Dvd video .now it will ask you to add the video files.so click on Add ,when adding the files is over click on Next.Now it will ask for burning speed select the lowest speed ,it will burn the cd with good quality........now finally click on Burn .and nero will start burning the cd when 100% is over click on finish ..that's it
Now one problem can occur while adding the files,that nero may not add the .wmv files.so to resolve this problem use video converter to convert the .wmv files to any other file that nero support like mpg..and when done follow the procedure given above.
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
May 01, 2008 | Adobe Photoshop 7.0 for PC
CyberLink PowerProducer 2 for PC Logo
55 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
