Question about Vulcan EF3 Deep Fryer
Vulcan fryer gas control knob will not turn
The unit had been disconnected for cleaning around and under it. The gas control knob was left in the on position. Once they connected the unit you can't turn the knob from on to off and then on again as the lighting instructions dictate. You can't light the pilot either. Please help.
  • rbindas Nov 21, 2008
    The knob was lubricated and freed with a pair of pliers. A problem was observed with the valve similiar to the problem resulting in a recall for hundreds of Robertshaw valves. However, the year did not qualify for the recall after everything else matched up. That is a great price on that valve which is in fact a 7000 series. The lowest I have found is 174 so far.
  • 21 Answers
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Posted on Nov 18, 2008
  • r carbo
    r carbo Nov 21, 2008
    YOU NEED A NEW 700 SERIES GAS VAVE I CAN GET THE VALVE FOR AT MY PRICE WHICH IS ABOUT 100$ LET US KNOW WHAT TO DO WHERE ARE YOU LOCATED YOU CANT GET THIS PRICE UNLES YOUR IN THE BIZ BUT I GET THE OK FROM FIXA ALL I NEED IS A VALID CREDIT CARD AND I COULD SHIP IT TO YOU
Gas valve knob continues to turn, won't lite pilot, although knob pushes in fine
Replace the knob. There is a groove that the knob uses to put the valve core in the right position.
Feb 19, 2016 | Vulcan LG400 Deep Fryer
Vulcan Gas Fryer Overheating
I'm confident that the issue is the thermostat. It's the only thing there to regulate temp and from the sound of it, it's not keeping up. The bulbs can gas out and then they're about as useless as an empty soda can as far as temp regulation goes.
Nov 22, 2007 | Vulcan EF3 Deep Fryer
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
I cant buy just the nat gas to lp gas conversion parts for a Vulc
call your gas supplier as they have reasonable sources for all of these parts. shame on vulcan.
Mar 31, 2009 | Vulcan EF3 Deep Fryer
Watermark Grille pilot prob
Your question is posted under vulcan fryers but the comment refers to a grill. Either way, I think your problem is gas pressure and/or supply related. You may need a new regulator, you valve may not be open all the way or any quick couplings you may have are not coupled completely or are faulty. What is happening is there is enough pressure to keep the pilot going, but when the larger route for the burner gas is opened the gas is quickly used up without proper resupply. A regulator installed backwards can have this same effect. Hope this helps
Oct 17, 2008 | Vulcan GR45 Deep Fryer
Wont come on
low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Aug 04, 2008 | Vulcan EF3 Deep Fryer
Control valve leaking (Vulcan LG300 Propane fryer)
must change gas control valve which will repair leak also
Jul 31, 2008 | Vulcan EF3 Deep Fryer
VULCAN EF3 PILOT, ON, OFF, KNOB NOT TURNING
That knob is a pilot safty valve it is not your problem. Your problem is the m/v signal generator. This is either a thermocouple or a thermopile depending on the setup of your model. Look for a small copper line coming from the pilot area going to the pilot safty valve that is the tcouple or tpile. Replace this and I am sure you will be good to go.
Hope this helps Ya
please rate me.
Jul 19, 2008 | Vulcan EF3 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Vulcan EF3 Deep Fryer Logo
307 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
