Question about Intertherm P3RA-048K Air Conditioner
Intertherm heater blows cold air.
My AC works but the heater just blows cold air. It started last night and when I woke the house was in the low 60's and the thermostat was set at 72, the heater ran all night.
  • mp1276 Nov 16, 2008
    My A/C is two years old, the thermastat was provided by Austin, Energy. The outside unit is old but seems to be responding just fine when the A/C is on Cool. Turning on hot and it just blows regular to cool air and the outside unit doesn't respond. I have cleaned the blower and wire connections. There is no standing water of any kind and I flipped all the circuits inside and outside of my building. Why would a A/C not heat but cool just fine is my questioin?
    Thank you.
  • dalexius Dec 02, 2008
    I have a 7 yr. old Intertherm central air/heat unit that works fine on a/c but on heat only blows cold air. Any help would be appreciated. Thanks
    Problem Solver:
  • 8 Answers
Do you have elec or gas heat? nat or propane?
Posted on Nov 16, 2008
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
Went to bed last night with heat woke up today everything house was cold, looked at thermastat it said 63degrees,, checked out furnace it starts up but doesnt ignite, sounds like its in the start up stage...
Does the hot surface igniter glow? If not, it is probably cracked. If this is
a 90% furnace, it could be that yuor intake air is causing the problem.
Dec 27, 2009 | Goodman GMS90703BXA Heater
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
May 11, 2009 | 2003 Ford ZX2
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
MY HAIER A/C IS NOT GETTING COLD
I have a fairly new Haier Air Condition that I bought last year, it has been working good up until last night. I keep this one in my bedroom and put it on every night since the summer. Last night I woke up very warm, the temp reading was 75 the AC did nothing but blow out just air. I threw away the booklet on it because I've had no problem up until now. Does anyone know how I can make it cold again. HELP!!!!
Jun 22, 2008 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
434 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
